airbox
Old Oct 24, 2002 | 02:04 PM
ROB281's Avatar
airbox
whats the easiest way to seperate the mas sensor from the box without damaging anything?
Old Oct 24, 2002 | 02:44 PM
importlancer's Avatar
Your best shot would be to spray some WD40 (or however it might be spelled) onto the bolts then take the socket and with a little force try to loosten the bolts up. I don't think many people, if any on this forum actually removed the MAS without grinding off the plastic walls surrouding.
Old Oct 24, 2002 | 02:49 PM
HobieKopek's Avatar
After breaking my first one I did vise grip on the inside and socket on the other side. Worked just fine.
Old Oct 24, 2002 | 03:02 PM
Yeah, well I stripped all the walls on mine because of my extreme weakness and grip resistant tools. I did use a socket and wrench but still didn't do much for myself.
Old Oct 25, 2002 | 07:38 AM
OZ_Rally's Avatar
for which intake is that needed to do...RMR,RRm,Injen,AEM or all of them
Old Oct 25, 2002 | 07:52 AM
wizardofoz's Avatar
Has to be the worst f---king design I have ever seen Wasted the airbox when I removed mine. If you have access to an air impact that is your best bet. I finally broke down and borrowed one after I had sheered 3 out the 4 sides on the box.
Old Oct 25, 2002 | 08:00 AM
Kurt's Avatar
What's up with the odd shaped bolt on the airbox? I was bleeding after the first bolt. Vise grip slipped.
