-   Lancer Engine Tech (https://www.evolutionm.net/forums/lancer-engine-tech-56/)
-   -   Engine Question (https://www.evolutionm.net/forums/lancer-engine-tech/234617-engine-question.html)
blackout24 Nov 13, 2006 10:01 AM
Engine Question
I have used the search and haven't been able to find anything on this question so here it is. Is it possible to put the turbo/non turbo headers off a 03 evo onto a 03 lancer es. :confused:
Wallesasuaz Nov 13, 2006 10:30 AM
well maybe you didn't search properly. Also, this is in the wrong thread. go to the Forced Induction thread and read some more. Some have done it, and use can use those threads as a guide!
gregivq Nov 13, 2006 10:39 AM
Anything is possible. Is it cost efficient? or worth your time? No.
Wallesasuaz Nov 13, 2006 10:52 AM
on another note. There is no non-turbo header of an EVO. If you get an evo header, which in reality is a Turbo Manifold, you're going to need to go turbo in your lancer.
gregivq Nov 13, 2006 11:00 AM
But you could attach a downpipe to that manifold instead of a turbo and that's your non turbo manifold :D It would stupid and pointless and retarded but hey, you could do it :D
Wallesasuaz Nov 13, 2006 11:04 AM
Good point Greg.... let's see who actually does it now...lmao
gregivq Nov 13, 2006 11:08 AM
*takes out popcorn and waits.
I hope they will know to port the head a bit to the right and make some extra holes for the screws since they don't line up. And make sure to drill holes in the head...not the manifold ;)
Wallesasuaz Nov 13, 2006 11:11 AM
OR, cut off the flange and weld a lancer flange to it for a direct fitment.
blackout24 Nov 13, 2006 03:57 PM
:D cut off the flange and weld a lancer flange to it for a direct fitment i think thats what i'm going to do but can i do that what would i need to get started tuesday?
ambystom01 Nov 13, 2006 05:06 PM
Question, why would you do this? If you're staying NA, get a real header, not a turbo manifold.
N1te Nov 18, 2006 09:09 AM
+12345
