Hanging RPM's
So I've noticed that for about a few hundred miles, and the issue is still there, my RPM's are hanging. What I mean by that is shifting from 2-3 or 3-4 etc, I let off the gas, push on the clutch but the RPM will just hang there for a second before actually dropping. Can anyone explain this irregular behavior and what can affect it?
Check to see if your clutch fluid is low.
As has been noted before, you have to over fill the brake side to fill up the clutch side. |
Brake fluid is full and brand new.
i have the same problem but iac CEL is on now
any ideas ppl
If you have a code for a bad IAC then that could very well cause the problem. The engine is reciving too much air through the IAC valve, causing the RPM's to hang. I would replace the IAC and see if it still occurs. Whats your VAC at idle? If its lower than normal check for intake leaks as well
only since my tune have 2 sensors gone bad! and my vac when driving and releasing the pedal is -19......maybe at idle is like -16 or closer to -19
Originally Posted by zulu989
(Post 8895986)
Are you guys running 9653 tephra roms? Or any evo rom from a 05+, they all have throttle hang issues, that can be ironed out with a few tweaks.
is there a thread how to stop it
(Post 8907750)
and this : https://www.evolutionm.net/forums/7580026-post11.html |
Originally Posted by HornstarBU
(Post 8910224)
On the 9653 rom, I fixed mine with this : https://www.evolutionm.net/forums/7596260-post61.html
and this : https://www.evolutionm.net/forums/7580026-post11.html +1 This removed my throttle hang also |
| All times are GMT -7. The time now is 09:42 PM. |
