Hanging RPM's
Old Oct 10, 2010 | 07:31 AM
Seifer780's Avatar
Hanging RPM's
So I've noticed that for about a few hundred miles, and the issue is still there, my RPM's are hanging. What I mean by that is shifting from 2-3 or 3-4 etc, I let off the gas, push on the clutch but the RPM will just hang there for a second before actually dropping. Can anyone explain this irregular behavior and what can affect it?
Old Oct 10, 2010 | 08:07 AM
mci2727's Avatar
Check to see if your clutch fluid is low.
As has been noted before, you have to over fill the brake side to fill up the clutch side.
Old Oct 10, 2010 | 09:17 AM
Seifer780's Avatar
Brake fluid is full and brand new.
Old Oct 10, 2010 | 10:01 AM
zulu989's Avatar
i have the same problem but iac CEL is on now
Old Dec 7, 2010 | 06:12 PM
zulu989's Avatar
any ideas ppl
Old Dec 7, 2010 | 07:00 PM
Mitsu.kid.02's Avatar
If you have a code for a bad IAC then that could very well cause the problem. The engine is reciving too much air through the IAC valve, causing the RPM's to hang. I would replace the IAC and see if it still occurs. Whats your VAC at idle? If its lower than normal check for intake leaks as well
Old Dec 7, 2010 | 07:08 PM
zulu989's Avatar
only since my tune have 2 sensors gone bad! and my vac when driving and releasing the pedal is -19......maybe at idle is like -16 or closer to -19
Old Dec 7, 2010 | 07:11 PM
Check for intake leaks, my idle VAC is -20 when warm at idle, when i release the pedal its -22, sounds like you may have a slight intake leak, as well as a bad IAC could be causing your hanging RPMs
Old Dec 10, 2010 | 11:25 AM
HornstarBU's Avatar
Are you guys running 9653 tephra roms? Or any evo rom from a 05+, they all have throttle hang issues, that can be ironed out with a few tweaks.
Old Dec 12, 2010 | 03:05 PM
zulu989's Avatar
is there a thread how to stop it
Old Dec 13, 2010 | 01:47 PM
HornstarBU's Avatar
On the 9653 rom, I fixed mine with this : https://www.evolutionm.net/forums/7596260-post61.html
and this : https://www.evolutionm.net/forums/7580026-post11.html
Old Dec 13, 2010 | 02:09 PM
widge's Avatar
Originally Posted by HornstarBU
+1
This removed my throttle hang also
WRC80Y
Jun 4, 2015 08:08 AM
Evorange
Feb 11, 2013 04:33 AM
white_evo27
Sep 15, 2012 09:32 AM
playmajohn
Dec 11, 2011 08:17 AM
lazyrichi3
Oct 25, 2011 07:43 PM
