so my DP fell off (story and a lesson)
i got to thinking: i'm wanting to go FI soon enough, so what would have happened if i was turbo charged and the same type of thing happened? supercharged? obviously different circumstances cause the exhaust drives the turbo, so perhaps that would have been more catastrophic?
Turbo - You'd just lose boost, basically.
SC - the same as in N/A. Just no backpressure.
or just weld everything nice and tight together
of course, you'll never be able to get it off, but meh
Hey, it could have been a lot worse when you look at it. Just be thankful nothing caught fire?
dam, i never thought of that. yeah, i know the ones your talking about, i'll see if i can find some around here
wait, whats the temp limit on that plastic though?
hmm, not quite. see, the bolts fell off when the car was on, ergo, when the engine was running, ergo when the headers were hot
when the headers are hot, they are hot enough to melt plastic. so at the time when i need the grip the most, the plastic would be a gooey mess, as someone pointed out before, lubricating the threads making the nuts vibrate off easier
You use *brand new* locking washers (and maybe bolts too.. they are cheap) and torque them down really tight when the car is cold.. (just think of how tight they were from factory specs when you had to get them off for the first time) That way when the car heats up and the metal expands, there is no chance of them coming off. Clean off the bolts and threads, then start over. After your run your car for a day or two, go back and check to see if they got loose. Tighten them up if necessary.
I'm not sure what they use at the factory, but they have some type of sealant that is for high heat applications. You might want to go to the dealership and see what it is called.
Actually loctite blue is -65 deg. to +300 deg. F same for loctite red. Difference between two is blue is for 1/4" to 3/4" bolt diameters and red is for 3/8" to 1" diam. bolts. also you need to heat up the loctite to get the bolt off( i think to either 450 to 500 degrees F) or use something torquey to get the seal broken.
Plus, make sure you get grade 8 bolts if you are to replace bolts on any part of the exhaust.
