Need Major Help: Battery Mishap
Old Sep 17, 2005 | 11:30 PM
stdreamy's Avatar
well, i was a dumb *** and decided to add a yellow top optima battery to my car..cool **** huh.. well..i was a total ****ing dumb *** and didn't pay attention to the + and the - side...****ty enough, they're reveresed from the normal batteries..well i hooked it up and got a gnarly spark and couldn't figure out for a few seconds what the hell happened because now my lights and everything was on but i had everything shut off......so i took it off and realized i had the **** backwards...well on the battery cables they have this little box on the + side and i noticed the fuse inside of it was blown...what purpose does that thing serve...and what is the likely possiblity that i ****ed my car up?
Old Sep 17, 2005 | 11:56 PM
camaro379ss's Avatar
its a protection from people doin things like that i believe, did u replace the fuse?
Old Sep 18, 2005 | 08:15 AM
SLVROZ_03's Avatar
"What purpose does that thing serve"...well, just what all the other fuses in the car do-electrical protection. And let me guess, that's a dealer only part...
Old Sep 18, 2005 | 10:08 AM
Moofahsah's Avatar
yea buddy if it werent for that fuse you woulda ****ed it up worse ... i think as long as you replace that fuse your straight ... fuses are their to blow so that you dont let the smoke out the wires and since it was your battery ...well lets just say your lucky it was just the fuse
Old Sep 18, 2005 | 10:40 AM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
If it tripped the fuse you're probably ok. I was giving a guy a jump start once and let him connect the cables (bad idea) and he started to do that. The sparks jumped and he corrected the problem. I wanted to deck him but my car was fine, so no big deal.
Old Sep 20, 2005 | 01:19 PM
dhonda's Avatar
I had a friend do one step worse to my eclipse. He dropped a socket wrench on the two posts and fry all sorts of stuff on my car.
Old Sep 20, 2005 | 01:22 PM
^i did that before i got distracted taliking to someone and i talk with my hands alot, so i let go of the ratchet and all it does is shoot sparks everywhere no biggy.
Old Sep 20, 2005 | 08:45 PM
stdreamy's Avatar
well...the ecu is fried...
Old Sep 20, 2005 | 08:48 PM
bobaab's Avatar
car doesnt start? sheesh, i would think the fuse for the ECU would have blown before it got ****ed like that. sorry to hear that man..
Old Sep 20, 2005 | 09:01 PM
Moderator
Bomb Squad Unit #02
If the jolt moves fast enough, it will jump before the fuse has a chance to fully blow. Sad that it happened, though, an ECU costs something like $600
Old Sep 20, 2005 | 09:32 PM
stdreamy's Avatar
well here's what's weird...the car starts...the lights turn on only when the key is in the accessory or turned on, all locks, windows only work when car is on..the clock is dead, my radio is dead, my dome light is dead..but all my dash lights work as well as lights to my window up and down switch..the car runs..but the idle is at like 400rpm..it's really acting weird like it's possed.
Old Sep 20, 2005 | 09:41 PM
7rider's Avatar
sounds like you blew your iod fuse. open the fusebox under the hood, and check them they are 10a fuses. your low idle problem, disconnect your battery again, then remove your isc motor, and clean all the carbon off of it. some brake cleaner works well. also spray some into the throttle body holes and make sure all of the sealing surfaces are clean. reinstall your isc, reconnect your bat then start it up. it will idle low for a while but it will recallibrate itself.
Old Sep 21, 2005 | 07:34 AM
7rider's Avatar
well did it help?
Old Sep 21, 2005 | 08:18 AM
SLVROZ_03's Avatar
Used ECU's are available on Ebay for pretty cheap if you end up needing one.
Old Sep 21, 2005 | 08:27 AM
blacklancerr's Avatar
<newb> whats an "isc motor"? </newb>
thanks
