Track Time before Turbo
Old Oct 1, 2005 | 09:13 AM
mitch44759's Avatar
Smile Track Time before Turbo
I went to my local 1/4 mile track and got some times before i put my turbo in hopfully next week. I ran 3 times and got these numbers, this was my first time.
#1 #2 #3
#1 - 1/8 11.231 @ 63.87 #2- 1/8 11.096 @ 63.61 #3- 1/8 11.026 @ 63.85
----- 1/4 17.305 @ 81.29 ------ 1/4 17.210 @ 80.23 ----- 1/4 17.112 @ 81.26
Do these numbers look right for the mods that I have on my car already?
Remmember it was the first time I went to the track.
Old Oct 1, 2005 | 09:18 AM
schepis's Avatar
Not bad, but you should be able to get into the high 16s
Old Oct 1, 2005 | 09:19 AM
gregivq's Avatar
Pretty good numbers. Stock lancer should be doing something around 18s. Good luck with turboing.
Old Oct 1, 2005 | 09:38 AM
AznFlip's Avatar
Not bad, but if I were you, I would get intercooled t/c instead.
Old Oct 1, 2005 | 09:43 AM
mitch44759's Avatar
I would love to but I need that stuff you know money LOL...
Old Oct 1, 2005 | 09:46 AM
travelsize420's Avatar
he can always upgrade to the intercooled turbo..
what were your 60ft times?>
Old Oct 1, 2005 | 09:50 AM
mitch44759's Avatar
60 Ft
1# 2.742 -- #2 2.582 -- #3 2.519
AznFlip's Avatar
Well just make sure not to over boost. You should hit around mid 15's.
Old Oct 1, 2005 | 09:55 AM
mitch44759's Avatar
I believe RRM's kit comes pre set to 5PSI which is well under the 9 PSI max so I will hopfull be ok.
Old Oct 1, 2005 | 09:57 AM
AznFlip's Avatar
The max you can go with non i/c is 6 pounds, beyond that, you'll need an i/c at least.
Old Oct 1, 2005 | 10:00 AM
mitch44759's Avatar
Thanks good info
Old Oct 1, 2005 | 04:59 PM
twisty1251's Avatar
you should use your stock rims at the track. that 60ft time is
Old Oct 1, 2005 | 05:28 PM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
Those numbers look fine. I think I was in the low 17s when I had a reflashed ECU and short ram intake. And totally stock manual Lancers were doing high 17s while autos were doing low 18s
