04+ Lancer Performance Mods Directory
Old Apr 7, 2006 | 11:52 AM
drucea's Avatar
Updated: 10/18/2007 -
I'm on the boards about 2 hours a day skimming through new threads. I'm also constantly looking for new parts for my 2004 Lancer. It gets frustrating having to search through threads with links to parts, but then getting there and seeing that its only for the 02-03 models. I've compiled a directory of parts specifically for 04+ Lancer. Performance parts only. Searching is now much easier by pressing Ctrl+F, typing the product you want, then it shows you. All you have to do is click the product link and you're there. The thread is organized by company, then product type. Clicking the company name link takes you to the Lancer portion of the website. Clicking the product type link takes you to that portion of the website. The folowing companies are in no specific order. Discussion on this thread is allowed but please do not ask about which product is better from which company (example: which company makes a better header?). There are plenty of threads discussing that and it only leads to arguements. Questions on the possible gains from certain products are allowed but I will ask mods to please remove any arguements from this thread to keep it clean. Any questions, comments, or info on new products for the Lancer not listed here, please let me know. Hopefully this thread helps out some people.
Drivetrain:
-Separate Turbo Kit Pieces and Fuel Management
-New 04-06 Turbo Kit
-Stage 1 Camshaft
-Ported and Polished Head
-Turbo Kit for Auto and Manual
-Hacker/Tweeker Turbo Starter Kit
-Front Mount Intercooler
-Piggyback ECU for Auto and Manual
-Piggyback Software
-Zeitronix Wideband
-Lightweight Aluminum Crank Pulley
-AEM Cold Air Intake for Manual
-RRM Cold Air Intake for Manual
-RRM Short Ram Intake w/ Carbon Fiber Intake Shield for Auto and Manual
-02-03 Ported/Powdercoated Intake Manifold
-04-07 Ported/Powdercoated Intake Manifold
-Bored Throttle Body
-Header w/ CEL Eliminator Installed
-CEL Eliminator
-Stainless Steel Clutchline
-Stage 1-2100 lbs. Clutch Kit
-Stage 2-2600 lbs. Clutch and Pressure Plate
-Aluminum Flywheel
-Front LSD
-Motor Mounts (w/ Carbon Fiber reinforced Filler)
-Magnacore Wires
-Weld-In Maganflow High Flow Cat
-Magnaflow Axelback Muffler
-Forged Pistons
-Pauter Rods
Suspension:
-KYB Replacement Shocks (OZ, LS, RA)
-KYB Replacement Shocks (ES)
-Toyo Tires-Proxes
-Front Rallispec X-Bar Strut Bar
-Front Single Tube Strut Bar
-Single Tube Rear Strut Bar
-Rally Series Lower Tie Bar
-Auto Cross Sway Bar Perches
-Rear Anti Sway Bar
-Rear Anti Sway Bar w/ Auto Cross Perches
-Progress Lowering Springs (OZ and LS)
-Progress Lowering Springs (ES)
-Eibach Pro Kit Lowering Springs
-TEIN Basic Dampner Kit
-TEIN Super Street Coilover Kit
-Camber Kit
-Street Series Slotted Disc Rotors (ES)
-Street Series Slotted Disc Rotors (OZ, LS)
-Race Series Slotted Disc Rotors
-Axxis Deluxe Brake Pads
-Axxis Ultimate Brake Pads
-Porterfield Carbon Kevlar Brake Pads
-Braided Steel Brake Lines
Quick Shifters:
-Short Shifters
Air Filters:
-K&N Stock Filter Replacement
-K&N Ram Pod Filter
Single Throttle Bodies:
-Bored Single Throttle Body
Twin and Quad Throttle Bodies:
-Performer Manifold
-Dual Throttle Body System
-Quad Throttle Body System
Extractors (Headers):
-Race Design Extractor
Exhaust Systems:
-Info on Good Exhaust Sizes
-Lukey Exhaust Components
Camshaft and Related Products:
-Stage 1 Grind
-Stage 2 Grind
-Stage 3 Grind
-Stage 4+ Grind
-Valve Springs
-Vernier Camshaft Gears
Cylinder Heads:
-Stage 1 Port and Polish
-Stage 2 Port and Polish
-Stage 3 Port and Polish
Turbo Kits:
-Stage 1
-Stage 2
-Stage 3
Nitrous Oxide Systems:
-Dry Nitrous System
-Wet Nitrous System
Brake Upgrades:
-Front Medium
-Rear Medium to Extreme
-Front Medium to Extreme
-Front Extreme
Conrod Upgrades:
-Modified Stock
-Aluminum Billet
-Forged Steel
-Billet Titanium
Drive Train Components:
-LSD
-Clutch Assemblies
-Carbon Steel Flywheels
-Polyurethane Engine Mount Bushings
Piston Upgrades:
-Hypereutectic Pistons
-Forged Pistons
Engine Conversions: (best to worst)
-6A13 SOHC 24 Valve Engine
-6A12 DOHC 24 Valve Engine
-6A12 DOHC 24 Valve MIVEC (highest recommended)
-4G93 DOHC 16 Vale Engine
-4G93 DOHC 16 Valve Turbo
-4G63 DOHC 16 Valve Turbo
Updated Price List for RPW
(RPW Dealer)
-RPW Header w/ Flexpipe
-RPW Header w/ High Flow Cat
02-03 Section-Fits 04+:
-Forged Pistons (9.5:1/11.5:1)
-Intake Manifold Phenolic Spacer
-Throttle Body Phenolic Spacer
Engine:
-RMR Short Ram Intake w/ Heat Shield
-RMR High Performance Exhaust
-K&N Typhoon Short Ram Intake
-Injen Cold Air Intake for Manual
-Injen Short Ram Intake w/ Heat Shield
-HKS Fan Controller
-Apex'i Super AFC2
-Apex'i Rev/Speed Meter GP
-AEM Air Filter Cleaner Kit
Drivetrain:
-B&M Short Throw Shifter
Suspension:
-RMR Strut Tower Bar
-Electronic Damping Force Controller
-TEIN S-Tech Lowering Springs (LS and OZ only)
-Swift Sport Mach Lowering Springs
-H&R Lowering Springs
Brakes:
-Wilwood Front Brake Upgrade
-Power Slot Rotors-Front
-Motul RBF 600-0.5L
Suspension:
-TEIN Super Street Damper Kit
Engine:
-Stage 2 Supercharger Drive System for Manual and Auto
-Supercharger Tuner Package
-Boost Cooler (water/methanol injection system)
-Overdrive Aluminum Crank Pulley
-Small Shaft Pulley
-30psi PCV Valve for Forced Induction
-Long Tube Headers
Transmission:
-Auto Transmission Cooler
-Engine Damper Kit
-Engine Damper Kit for RRM X-Bar
-Engine Damper Kit 2
All Custom Colors.
-Fire Extinguisher Bracket
-Front Strut Tower K-Bar
-Rear Strut K-Bar Brace
-Rear Strut Tower Brace
-Rear Sub Friendly Strut Brace
-RS Style Trunk Bar
-Lower Tie Bar
-Front Stur Bar, Rear Strut Bar, Lower Tie Bar Package
-F5 Fujita Cold Air Intake for Manual
-Power Slot Front Brake Rotors (LS and OZ only)
-Kamikaze High Luster Ceramic Coated Headers
-Kamikaze Hi Temp Black Coated Headers
-Kamikaze Header Downpipe (I believe needed to fit headers to stock exhaust)
-Magnecor KV85 Competition Ignition Cable Set
-Denso Iridium Power Spark Plug IK Series
-SPC Front Camber Correction Kit
-Progress Lowering Springs (ES only)
-Progress Lowering Springs (LS and OZ only)
-Freedom Design Lower Tie Bar
-Freedom Design Front Strut Bar
-Freedom Design Rear Strut Bar
-Progress Rear Lower Sway Bar (OZ only, ES and LS require other parts to fit)
-Techna Fit Braided Steel Clutch Line
-Fidanza Lightweight Billet Aluminum Flywheel
-B&M Short Shifter
-B&M 2-Way Adjustable Short Shifter
Engine:
-RPW Vernier Cam Gears
-RPW N/A Stage 1 Camshaft
-RPW N/A Stage 2 Camshaft
-RPW Turbo Stage 1 Camshaft
-RPW Turbo Stage 2 Camshaft
-RPW Stage 1 Head Gasket
-RPW Stage 2 Head Gasket
Transmission:
-RPW Clutch Kit
Suspension:
-TEIN Basic Coilover Kit
-TEIN Hi Tech Lowering Springs
-TEIN S Tech Lowering Springs
-Arospeed Front Strut Bar
-Arospeed Rear Strut Bar
-Arospeed Lower Tie Bar
-Koni Street Special Shocks
-KYB Front and Rear GR2 Shocks
Exhaust Components:
-RPW Street Headers (no flex pipe)
-RPW Race Headers (flex pipe included)
-RPW Turbo Manifold
Universal Mufflers:
-Apex'i N1 Canister (turbo and N/A)
-Apex'i N1 Colored Canister (turbo and N/A; gold, blue, black, magenta, green)
-DC Sports Canister
-HKS Carbon Wrapped Canister
-HKS Stainless Canister
-Injen Canister
-Skunk2 Canister
Electronics:
-Apex'i AVC-R Boost Controller
-GReddy Profec B Spec II Boost Controller
-GReddy Profec E-01 Boost Controller
-GReddy TVVC Mechanical Boost Controller
-HKS EVC EZ II Boost Controller
-HKS EVC V Boost Controller
-Apex'i SAFC2 Fuel Controller
-HKS GCC Fuel Controller
-Apex'i Apex Turbo Timer
-BlitZ DTT Type X Turbo Timer
-Blitz Dual T/T DC III Turbo Timer
-Blitz FATT D1 Spec Turbo Timer
-Blitz FATT DC III Turbo Timer
-Blitz FATT Type X Turbo Timer
-GReddy Turbo Timer
-HKS Type 0 Turbo Timer
-HKS Type 1 Turbo Timer
Fuel Delivery:
-Apex'i Fuel Injectors
-Blitz Fuel Injectors
-GReddy Fuel Injectors
-HKS Fuel Injectors
-MSD Fuel Injectors
-Precision Turbo Fuel Injectors
-RC Engineering Fuel Injectors
-RPW Fuel Injectors
-HKS Fuel Pump (external or in-tank)
-Vortech Fuel Pump
-Walbro Fuel Pump (hi-flow and in-line)
Forced Induction:
-RPW Stage 1 Turbo Kit
-RPW Stage 2 Turbo Kit
-Apex'i Blow Off Valves
-Blitz Blow Off Valves
-GReddy Blow Off Valves
-HKS Blow Off Valves
-TIAL Wastegates
Old Apr 8, 2006 | 04:06 PM
drucea's Avatar
Arrow List Continued
I guess I'm only allowed 20000 characters per post so I'm continuing the list here:
-Exhaust Hangers
-Short Throw Shifter
-Shifter Base Bushings
-Shift Linkage Bushings
-Shift Knob
Deyeme Racing: (click Show Parts For Lancer)
-DMR Battery Tie Downs
-DMR Radiator Brackets
-DMR Drivetrain Mount (motor mount) Front and Rear
-Weld-In Exhaust Piping
Engine:
-WORKS High Flow Drop-In Air Filter
Drivetrain:
-Clutch Kit 1
-Clutch Kit 2
-Shifter Bushing Kit
-WORKS Spin Lightweight Flywheel
Brakes:
-Ate Super Blue/TYP 200 Brake Fluid
-Motul RBF 600 Brake Fluid
Engine:
-Vivid Racing Battery Tiedowns
Intakes:
Suspension:
Coilovers:
-JIC FLTA2
-KW Variant 1
-TEIN Basic Dampers (OZ only)
Springs:
-Eibach Pro Kit
-Progress Sport Kit
-Progress Sport Kit (OZ)
-Progress Sport Kit (ES)
-TEIN S Tech (OZ)
-Tenzo R Sport Type (OZ)
Transmission:
Clutch:
-Clutch Masters Stage 1 (OZ)
-Clutch Masters Stage 3 (OZ)
-Clutch Masters Stage 4
Flywheels:
-Fidanza Aluminum Flywheel
Shifters:
-B&M Precision Sport Shifter
BRAKES:
Big Brake Kits:
-Precision Big Brake Kits
-Rotora Big Brake Kits
Brake Pads:
-Axxis Pads
-EBC Pads
-Hawk Pads
-Porterfield Pads
-Rotora Pads
Brake Rotors:
-Brembo Rotors
-EBC Rotors
-Power Slot Rotors
-Rotora Rotors
CLUTCH:
Clutch Disks:
-RMR Disks
-Exedy Disks
-Blitz Disks
-Tilton Disks
Clutch Kits:
-ACT
-Unorthodox
-Clutchmasters
-Zoom
-SPEC
-HKS
Clutch Lines:
-Techna Fit
Throwout Bearings:
-Stock
-Tilton
STILL ADDING
Brakes:
-B&M Launch Control
-Brembo Drilled Brake Rotors
-Brembo Slotted Brake Rotors
-Hawk Ceramic Brake Pads
-Hawk HPS Brake Pads
-Wilwood Big Brake Kit
-Wilwood Drilled Big Brake Kit
-Wilwood Flexline Big Brake Hose Kit
Driveline:
-Agency Power Evo Short Shifter
-Agency Power Shifter Bushings
-B&M Short Shifter
-Clutchmasters Stage 1 Clutch
-Clutchmasters Stage 3 Clutch
-Clutchmasters Stage 4 Clutch
-Fidanza Flywheel
-Fidanza Short Shifter
Engine:
-ARP Head Studs
-NGK Iridium Spark Plugs-Turbo
-NGK Premium Ignition Wires
-NGK Spark Plugs-N/A
-Pauter Rods
Fuel:
-Walbro 255 Fuel Pump
Intake:
-Injen Cold Air Intake-Black or Polished
-Injen Short Ram Intake w/ Heat Shield-Black or Polished
-K&N Drop In Filter
Suspension:
-Eibach Pro Kit Springs
-Energy Suspension Front Sway Bar End Links
-KYB GR2 Shocks (OZ/LS Only)
-KYB GR2 Shocks (ES Only)
-Megan Street Series Coilovers (all trim levels)
-TEIN Basic Damper Coilovers (all trim levels)
-TEIN H-Tech Lowering Springs (OZ/LS only)
-TEIN S-Tech Lowering Springs (ES only)
-TEIN S-Tech Lowering Springs (OZ/LS only)
Old Apr 8, 2006 | 05:03 PM
Slovak's Avatar
You can add short shifter under KartBoy, theirs fits our cars perfectly, along with the base and shift linkage bushings
Old Apr 8, 2006 | 08:21 PM
thereasonsf3's Avatar
damn i cant find 2.5' cat back exhaust or down pipe worth crap! i been looking for them past 6 hours everywhere. that one website has some up to 3' but no type of pics with them. i guess ill go custom.
awesome thread man
Old Apr 8, 2006 | 08:56 PM
drucea's Avatar
buschur racing used to have a nice catback that fit the 04+ but they stopped making parts for us. And I see youll soon be turboed. Just wait and when you get then turbo on, get a custom catback with a magnaflow or greddy muffler. youll like it much better than having to mess with it twice. If you hurry, RRM has GReddy weld-on mufflers for $79. prolly the best deal on a good muffler youll find.
Old Apr 8, 2006 | 09:00 PM
drucea's Avatar
Heres for RRMs $79 GReddy weld-on mufflers: https://www.evolutionm.net/forums/sh...d.php?t=150864
And heres theyre weld-on high flow cats for I think $99:
https://www.evolutionm.net/forums/sh...d.php?t=180853
Both are pretty damn good deals in my opinion
Old Apr 9, 2006 | 09:56 AM
yeah but i need 2.5' inch piping. thanks for the help btw . but yeah i think ill most likley go custom.
Old Apr 9, 2006 | 11:57 AM
drucea's Avatar
thats what i mean, when you go custom you can have whatever size you want for the piping cause all muffler shops have different sized pipes and they just bend and cut to fit under your car. and youll need a muffler on there, so get 2.5" piping custom made with a muffler and high flow cat welded all the way up to your headers so that you have the entire exhaust side covered. trust me, you wont be disappointed
Old Apr 18, 2006 | 07:51 PM
jmoney's Avatar
we need a body parts directory next you know part 2 . chop chop hop 2 it
Old Apr 18, 2006 | 10:24 PM
drucea's Avatar
i was thinking about doing that too. I prolly will cause thats just as needed and as important. We'll see how I feel tomorrow
Old Apr 29, 2006 | 06:48 AM
MK3Design's Avatar
Thanks for the links
Old May 1, 2006 | 09:28 AM
newbiewonkenobe's Avatar
03+ guage pods for ALL lancers
http://www.amstuning.com/amsgwpods/ These guys sell guage pods that fit all 2003+ lancers! woohoo! YES! even the es!
Old May 1, 2006 | 09:38 AM
Silens's Avatar
uhm... to my understanding any evo gauges / interior will fit any lancer .... somebody correct me if im wrong but the only difference in the 06 is the hazard light area?
Old May 1, 2006 | 10:05 AM
Z_Lancer_Man's Avatar
^^ You are correct. Any EVO gauge pod will fit all the Lancers - however, the color of the part might be different since the EVO interior is black.
Old May 1, 2006 | 12:12 PM
drucea's Avatar
all pillar parts fit all lancers. es ls and oz and ra have no differences in fitment or shape, just color and texture
