Very strange question
Old Mar 19, 2002 | 11:52 PM
ryland's Avatar
Um I dont know if this is going to sound dumb but you can tell me if its a dumb idea if you wish. What would I have to do in order to rip out the EVO 7 motor and put it in my OZ if possible. Such as will it fit. What would I have to change in all? And so on . Let me know if its a bad idea or whatever your feedback might be.
Old Mar 19, 2002 | 11:55 PM
pjal84's Avatar
This has been brought up before I believe. Run a search for "swap", "drop" and "4g63" or any combo of the words. Lot's of money though...new transmission, you'd need to move some stuff around to accomadate the AWD setup...etc....
Old Mar 19, 2002 | 11:59 PM
Lan Evo's Avatar
Here is a thread that should help you...Mirage and Lancer have a similar problem. BTW, a "used" EVO VII engine, with tranny, ECU, all sensors and wiring harness should cost around $10K...not the kind of budget project I have in mind.
http://www.lancerforums.com/forums/t1943.html
Old Mar 20, 2002 | 12:07 AM
ryland's Avatar
Thankyou guys so much!
Dude you guys rock. Thanks I will take that coversion into consideration. I dont know it seems cheap to me but then there will be install and I will have to ask about the warranty. heh I dont think there will be one anymore. Well I will keep checking back on this thanks guys.
Old Mar 20, 2002 | 12:09 AM
pjal84's Avatar
Re: Thankyou guys so much!
Mwaha...warranty...if you're considering something as massive as a full engine/tranny swap...that should be the last thing on your mind...hehehehe...
Old Mar 20, 2002 | 12:21 AM
Lan Evo's Avatar
Keep in mind, AWD will not work unless you cut the rear floor panel of the car and use an EVO counterpart...Labor costs will be sky high...
