How do you go about re-charging K&N style filter????
Old Jun 30, 2003 | 06:49 AM
Volkmann's Avatar
Question How do you go about re-charging K&N style filter????
Hey guys I know there are recharging kits for K&N style filters but how do you clean the filter???? Take it off and spray it down with the bottle of cleaner?????
Old Jun 30, 2003 | 06:59 AM
sanjaya1's Avatar
The recharge kit comes with a cleaner and a lubricant. There are pretty easy to follow instructions on the bottles. Basically you spray on the cleaner and let the filter sit for about 10 minutes. Then you flush it with water, from a tap (not to hard) in opposite direction from the airflow. This is to get out embedded dirt particles instead of driving them in further into the filter. Then let it air dry, which might require you to leave in alone over-night. Then spray on the lubricant, let it soak for a few minutes, reapply as required to cover the whole filter (you don't want areas on the filter to dry out and crack). Finally, reinstall the filter in the car. As I said, you get easy to follow instructions with the bottles.
Old Jun 30, 2003 | 07:02 AM
Volkmann's Avatar
oh ok thanks man.
Old Jun 30, 2003 | 07:17 AM
Volkmann's Avatar
just realized I haven't cleaned the filter.
Old Jul 5, 2003 | 03:38 PM
02izzel's Avatar
thanks for reminding me! i gotta re-charge my drop in K&N. about how much is the 'recharger'? does only K&N make them?
Old Jul 7, 2003 | 02:00 AM
diyath's Avatar
$10 at Autozone. Use only K&N cleaner and charger oil.
Old Jul 13, 2003 | 12:43 PM
Volkmann's Avatar
Just an update I cleaned and re-charged filter and man it looks brand new and super easy to do. Weird how the filter turns white from the cleaner and how the oil is red and makes the filter look new.
Old Jul 13, 2003 | 07:54 PM
pjal84's Avatar
Originally posted by rchi111
How often should you clean it? I have had mine in there about 20,000.
Do as I do with my HKS SMF's and that's everytime you change the oil. At least you have it cheaper...
Old Jul 14, 2003 | 10:24 AM
Volkmann's Avatar
My car had about 10,000 miles on it and filter looked dirty so I pulled off and cleaned. The re-charge kit says to clean at 50,000 and 100,000 miles but that seems to long to wait imo.
