It is time to move on...
Old Jan 9, 2008 | 02:17 PM
iufan4lifeul's Avatar
UPDATE!! For right now I am planning on keeping my car until at least the summer. Until them I am going to get ECUflash and EVOscan. Slightly bigger injectors (as I am taxing the limits of my stock ones), remove the MAF restrictor plate, and then tune away I am expecting some good gains since I will finally get a good A/F and then be able to alter timing etc.
Old Jan 9, 2008 | 02:41 PM
ambystom01's Avatar
How do you know you're maxing out the stock injectors? I would be very surprised at that considering even turbo guys can use the stock injectors.
Old Jan 9, 2008 | 03:31 PM
I took off my MAF restrictor plate, tried to tune with the SAFC and got to +50% fuel (maxed out the SAFC) and was still running 18:1 AFR so I am figuring I am maxing the stock injectors. Not sure what else would cause this.
Old Jan 9, 2008 | 03:32 PM
ambystom01's Avatar
I highly doubt you're maxing the injectors, my guess is it's either a problem with the SAFC, a problem with removing the restrictor plate or a problem with the stock ECU adapting.
Old Jan 9, 2008 | 03:51 PM
we'll see, I just put 2 and 2 together. If I come across some cheap injectors I might just swap them out for the hell of it just to make sure.
Old Jan 9, 2008 | 03:52 PM
ambystom01's Avatar
Well the way I see it, if turboed lancers can run without new injectors, an NA one sure as hell doesn't need them.
Old Jan 9, 2008 | 03:59 PM
Blacksheepdj's Avatar
Agreed.
Regardless, he's going to be better off going with something like a flash rather than using the piggyback.
