OEM Sun Visors in Lancer 2009
One thing I am very disapointed in is how cheap the OEM visors are in my 09' GTS. It's so flimsy it bends when I pull it with normal force to undo the latch which feels like it's going to pull away. Also the material its made with is cheesy, should be made with the same material that they put on the roof of the interior IMO. Or at least the vinyl stuff they used should be glued/sealed down to the foam inside, instead there is like a air pocket in there on both sides... Does anyone else think these are less then acceptable quality?
