Turbo or N/A
Old Sep 26, 2003 | 09:21 PM
Lancer_racer's Avatar
Question Turbo or N/A
I am thanking about buying the 2003 OZ Lancer, is it better to go Turbo, or just stick with the n/a setup and go for intake and exhaust.
whats every ons openion.
and yes i want crazy absean amounts of HP. i want to have the fastest OZ Lancer out ther and yes I am planing on puting in the forged pistons.
Old Sep 26, 2003 | 09:24 PM
ozlancer0z's Avatar
you want power? go tÜRBO!
Old Sep 26, 2003 | 09:26 PM
pumpdog720's Avatar
Well ofcourse you are going to get more power with a turbo... do all the N/A stuff to ofcourse to go along with the trubo.
Old Sep 26, 2003 | 10:02 PM
SAEVO's Avatar
TURBO..... the only way to go
Old Sep 27, 2003 | 06:30 AM
tenkawa_akito's Avatar
going either NA or turbo depends on your money situation. turbo-ing the lancer is no small endeaver and costs a lot. low compression pistons are a must if you plan on running 8 or 9 PSI constantly. I would consider a metal headgasket and strengthened head bolts too if you plan on going higher than that. road race's intercooled system is currently 4 large, but once you add in more of the wonderful hidden costs, that price could easily rocket you up into the 6 grand region.
i've owned both NA and FI sports cars, and I do have to say I enjoy the FI much more. They just take more TLC and attention than an NA car.
Also, don't get a blow off valve. find a nice diverter valve. The Mitsu 1G DSM is a big favorite (i'm currently running one and I like it). Also also, get a turbo timer. you'll thank yourself in the long run. I need to get off my *** and order one for the 240, but until then, I get to sit in the car while I idle the engine for a minute or two to let the turbo cool down. Wee.
If you don't have it, find a copy of Sport Compact Car's June issue. It's all about boosting. And they run a section on DV's and BOV's. Good luck!
Old Sep 30, 2003 | 09:19 AM
Which Turbo should i go with. I want crazy amounts of hp and torque. which turbo should i go with the Road Race inercooled turbo or the 3 staged RPW turbo kit. does any one know a good place to bye a light whate racing fly whele and a gooooooooooooooooood! clutch kit. I like to rip up the clutch on the road
Old Sep 30, 2003 | 09:23 AM
Guru_Del's Avatar
well if you are going after Boe for the fastest lancer I suggest you talk to him to make sure you are certain that is the path you want to take.
He is turbo, intercooled and TONS of other work. I suggest you call over to RRM as they know speed and they know our cars.
