just weighing my options
Old Jun 15, 2009 | 03:48 PM
scorpionx13's Avatar
so.
today my oil started leaking. and the oil pan is def busted from the exhaust hitting it (being too close)
the guy at the muffler shop gave the estimate of $300 for
weld of the oil pan
putting a dimple in the exhaust- to prevent in future
i was thinking about getting a new pan for $50 (or so?), then buying a custom curved pipe (he said he could do for $150) to get around the oil pan (just the small "L" shaped section in the exhaust). since i dont have welding or any sort of high heat tools at my house
i mean it saves about $100, so it sounds like a good idea.. just wanted to hear if u all think anything different.
thanks a lot!
Old Jun 15, 2009 | 03:58 PM
bcollinstex's Avatar
sounds like a good idea to do, check the junkyards, you may be able to get a lower oil pan for next to nothing
Old Jun 15, 2009 | 05:05 PM
sXericerider's Avatar
I would go for replacing the oil pan. Seems cheaper and I would go for the least expensive route to fix such a minor thing.
Old Jun 15, 2009 | 06:36 PM
Green_Bandit's Avatar
Yeah, that's what sucks about the RRM kit. Mine was against the lower oil pan but a took a good ol hammer and dented the down pipe. I would have never thought it could do that though. I'll have to keep an eye on mine.
As far as going to a junk yard...good luck. If you can find a junked Lancer anywhere close to here let me know cause I want some thing myself.
But as far as options. Dent up that DP or get that custom one. Check at Mitsu and see how much the lower oil pan is. It might not be that much...
Old Jun 16, 2009 | 09:26 AM
-update
yup.... no lancers in junkyards up here haha.
and u hammered ur dp green bandit? thats an option i guess, i just dont know about the long run for that.
ima check on the price of that lwr oil pan today
Old Jun 16, 2009 | 06:20 PM
ok problem fixed so far.
emptied the oil pan and put some jb weld on the small slit.
took off the exhaust dp and took a ballhammer to it *thanks green bandit
$300 project to $10 project (broken bolts, gaskets)
ill check it out in the mornin
