Maf Sensor
Old Jun 24, 2010 | 04:33 PM
Defcon5Es's Avatar
Maf Sensor
Do you have to remove the battery before removing the Maf Sensor?
Old Jun 25, 2010 | 07:34 AM
senate6268's Avatar
No. You can remove the MAF without removing the battery. But if you are installing a new MAF sensor, I recommend resetting your ECU afterwards by disconnecting the negative battery terminal for 20 minutes and letting your car idle for 20 minutes after starting it.
