o2 sensor
Old Sep 17, 2010 | 07:30 PM
Lancerboi808's Avatar
o2 sensor
hey guys i have this code p0135 02 sensor error
just done installing the turbo and for the 02 sensor where can i relocate the stock o2 sensor???
and where can i install the aem wideband 0s sensor?
any suggestions
car start up to 5000rmp and down to 500
data logging with evoscan and
afr reads 50.xxxxx
boost reads 10.xxx
i know i need to get it tune but i need to correct the engine light code
so LMK
thanks
Old Sep 26, 2010 | 06:54 AM
Mitsu.kid.02's Avatar
any suggestions
afr reads 50.xxxxx
boost reads 10.xxx
so LMK
thanks
The stock 02 sensor will go into the 02 housing comming off off the hotside of the turbo, depending on your set up you might need to lenghen the 02 sensor wires ***but do not cut the actual sensor wires, cut them from behind the connector*** The wideband should be installed on the downpipe somewhere..I installed mine right at the end of the downpipe...if its too close to the heat the sensors life will be very short, they are sensitive to extreme heat, also consistant rich conditions shorten the WB 02 Sensor as well. Make sure when you weld the bung on the pipe its atleast 10 degrees angled, this way all the condensation in the pipe thats collected on the sensor can drain out!
