What's A Good Brand Battery Replacement for OEM, Panasonic.
Old Dec 10, 2011 | 10:28 PM
GlicK's Avatar
Looking for a Battery Replacement on Lancer ES 2010. Thnks.
Old Dec 11, 2011 | 10:52 AM
djblinx's Avatar
You can never go wrong with an Optima color top or a Duralast Gold, both can be found at autozone.
Old Dec 12, 2011 | 06:32 AM
Blacksheepdj's Avatar
Seriously, unless you're doing some heavy-duty audio-visual work, just buy the cheapest battery you can find. It will work fine for many years.
If you really need to spend extra money on something, Optima would be my recommendation on name alone.
Or if you actually want to improve your car a tiny bit, change to a mini battery to save a butt-load of weight on the front of the car.
Old Dec 12, 2011 | 06:47 AM
escodotcarter's Avatar
optima color tops are way overpriced in my opinion. Since you live in Canada find the battery with the highest CCA rating and call it a day. DieHard from Sears are great too.
Old Dec 12, 2011 | 07:01 AM
2006_RA's Avatar
The cheapest battery with the highest CCA that fits.
I had a battery from Walmart that worked fine, sold it for $25 when I recently changed my battery (because I am installing an audio amplifier) to a Diehard Gold because that was the cheapest one that fit with a higher CCA rating.
In the end they are all lead acid accumulators using the same chemical reactions.
Xmas is coming, save your money for gas, liquor and lap dances.
Old Dec 12, 2011 | 01:21 PM
Old Dec 13, 2011 | 12:17 AM
GlicK's Avatar
Right now I have 2 subwoofers, rated at 700w and Class D sub in the trunk. No Capacitor, 1 Farad. All is working fine, no fluctuation in power. Especially with the Lights. When I turn on the defroster, headlights dim, but not substantially low.
Also, the temperature can dip as low as -40C / -40F. The car needs to be turn on at least once a week in order for the battery not to freeze.
Thank you all.
Old Dec 13, 2011 | 05:56 AM
lanzerralliart's Avatar
EvoM Super Moderator
I would have to say Optima, they are a little pricey ,but they come with the 36 month free replacement warranty. Of which I was recently able to take advantage of since mine died at the 30 month mark (probably due to 2 15" subs) , but now I'm rockin a new yellow top for free
FALCO
Mar 10, 2013 02:52 PM
Lancer XI1
Nov 4, 2010 12:08 AM
fasfour
Oct 5, 2010 12:17 PM
J8dailo
Jul 20, 2010 10:27 PM
