Caliper base bolt - Size?
Old Dec 17, 2011 | 03:44 PM
nosreme722's Avatar
So i had replaced most of my front suspension myself - discs, calipers, pads, controls arms, and struts and one day i started to hear a noise coming from the front left tire.
Didnt quite trust it so i checked it out and i could pretty easily tell the brake dust cover was touching the disc and that was causing the noise and some resistance and tried to bend it away. It was a bit loose so i checked the inside and saw one of the two caliper base bolts wasnt there...
So i need to know the size/specs so i quickly get a new one. I figured the bolt missing allowed the dust plate to come lose and rub against the disc. I put all bolts in with an impact wrench and double checked everything, along with a trusted mechanics approval. And its about 20 minutes away from me so i cant really just go look at it.
Old Dec 18, 2011 | 08:16 PM
nosreme722's Avatar
Anyone?
Old Dec 18, 2011 | 08:22 PM
Fox Fader's Avatar
So you are saying, that bolt was put in properly then checked by a mechanic and it still came out?
Take one of the other ones out and take it where ever and have it matched. They are all the same.
Old Dec 18, 2011 | 08:27 PM
nosreme722's Avatar
Well.. i dont think the mechanic went and torqued each bolt but he pretty much approved of everything (which i guess doesnt mean much). Anyway im going to a dealer tomorrow, hopefully they'll have it.
Old Jun 22, 2012 | 08:08 AM
pbrady5's Avatar
Did you ever find a resolution on this size? I have the same problem and have not been able to track down a replacement caliper bolt..
Old Jun 22, 2012 | 08:26 AM
CrAnSwIcK's Avatar
bolt sizes are specified in ASA...
Old Jun 23, 2012 | 07:30 AM
pbrady5's Avatar
Thank you for taking the time to reply back and answer my question! I hate to be overly ignorant, but I don't know what the ASA is?
Drew314
31
Feb 16, 2020 04:34 PM
allday10sec
May 4, 2017 08:51 AM
Kwah1984
Dec 4, 2015 01:20 PM
Ayyrock
Jul 20, 2015 04:47 PM
JRitt@essex
Sep 2, 2014 10:09 AM
