RRM Upper Front Strut Bar and Master Brake Cylinder
Old Jun 6, 2012 | 07:25 PM
Sanzie99's Avatar
Hey everyone,
Recently bought the RRM upper front and rear strut bars, lower sway bar and lower tie bar.
Everything installed fine except for the upper front strut bar. This is because the master brake cylinder is in the way and the strut bar cannot be installed.
What I want to know is if any of the Evo master brake cylinders would fit and are a different shape that would allow it to be installed.
My car is a right hand drive car as I am in New Zealand. The only alternative I can see is re-adjusting the RRM strut bar by cutting the welds and re-welding it in a different position. However I'm not sure if this will have an impact on the results from the strut bar and obviously will void my warranty.
I have contacted RRM as well but just thought I might drop a note on here to see what anyone else can come up with.
Cheers,
Sanzie
Old Jun 7, 2012 | 01:54 AM
lanzerralliart's Avatar
EvoM Super Moderator
Nice list of things you picked up,I have everything you bought. It's a nice addition for sure
The rrm x bar sits close to the master brake cylinder but it fits. Did you torque down one side then try the other side but it didnt work? That was my mistake as well. You will need to bounce back and forth, torque one on the drivers side , then one on the passenger side , repeat. That's how I got mine installed.
Old Jun 7, 2012 | 02:51 AM
Sanzie99's Avatar
Yeah have tried that, I think the issue is that the RRM strut bar is not identical on the angled bars the left side is longer than the right, this means it overlaps the MBC for me.
Not sure why the images aren't loading, you can right-click and copy image URL to see them.
Last edited by Sanzie99; Jun 7, 2012 at 02:53 AM. Reason: Trying to get images to work
Old Jun 9, 2012 | 09:08 PM
Sanzie99's Avatar
It's really just the reservoir that's getting in the way. Is there another Mitsubishi car model which reservoir will fit? Galant, Colt, Mirage, Evo?
Old Jun 13, 2012 | 09:51 PM
Sanzie99's Avatar
Bump, anyone able to help?
ikuto
Oct 18, 2011 09:40 PM
10thAnv
Apr 27, 2007 12:51 PM
mtags24
27
Mar 1, 2006 08:23 PM
pumpdog720
Jun 8, 2005 11:10 PM
2002OZ
Lancer Troubleshooting
13
Oct 17, 2003 06:22 PM
