fender question
Old Feb 24, 2004 | 01:56 PM
andy_1985's Avatar
fender question
I was wondering if anyone knew how to take the fendor of on the lancer OZ. I tried unscrewing the fender and it just kept unscrewing and never completly came off. As you can see i don't know much about taking a fender off if you could help me.
Old Feb 24, 2004 | 02:01 PM
pgmike's Avatar
what do you want to take the fender off for?
Old Feb 24, 2004 | 03:13 PM
andy_1985's Avatar
because i do a lot of fiberglass work and i am wanting to take the fender off to make a mold of the fender to make a fiberglass Z fender or a different fender.
Old Feb 24, 2004 | 03:19 PM
pgmike's Avatar
i want wider fenders (similar to ones on jettas) for a more aggresive look.
Old Feb 24, 2004 | 03:25 PM
imapunkclaimer's Avatar
im not sure what your problem is, but you can start by taking off the plastic around the wheel well to get a cleaner uninstall.
then theres a few bolts under the hood, you can try those also, but i have never completely took my fender off before although the bolts should come off unless theyre stripped somehow.
try prying teh bolt up while unscrewing it and see if thats where your problem is.
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
sounds like you're talking about the plastic plugs? You unscrew the center part a few turn and then pull the whole plug out.
Old Feb 24, 2004 | 09:54 PM
andy_1985's Avatar
no i'm talking about the bolts under the hood they just keep turning without coming up at all its weird and they aren't striped that i know off because they look like they haven't been touched since it was first put on because the paint was still over them.
