How do i get the oil pan off?
Old Mar 27, 2004 | 09:09 AM
pgmike's Avatar
I took all the bolts off but there is a really strong sealant on it that isnt letting me pry it off. I already tried wedging a small screwdriver between it but it isnt working. Crap all the west coast ppl are still asleep.
Old Mar 27, 2004 | 09:48 AM
bahamut's Avatar
Don't use a screwdriver. it will put a dent on the pan. Use a oil pan scrapper from NAPA or any auto parts store.
Old Mar 27, 2004 | 10:49 AM
Graeme's Avatar
The oil pan is sealed on with RTV instead of an actual gasket. When you put it back on, make sure you scrape off all the old stuff, and put on new RTV. Just go up to your local parts store and ask for a tube of "RTV Sealant". Shouldn't be more than $5
Old Mar 28, 2004 | 08:54 AM
pgmike's Avatar
what is an oil pan scraper?
Old Mar 28, 2004 | 08:55 AM
pgmike's Avatar
ive been tryig to get the oil pan of for a day and a half now and i cant get it off. seriously somebody has to know so help me.
Old Mar 28, 2004 | 09:03 AM
DOOMID@TeamD's Avatar
Former Vendor
Dude,
this isnt a flame, but if you cant get your oil pan off, maybe you shouldnt be working on your motor. Hire someone... If you continue on just keep working at it with the scraper at different points all around the pan, it will release eventually, dont get so frustrated. What are you trying to do anyway?
Old Mar 28, 2004 | 09:19 AM
twinkiemobile's Avatar
ok.. and an oil pan scraper.. which is basically a tool that is very thing.. and a little sharp at the sides.. almost like a knife.. and what i did was when i had to install mine.. is you just kinda force it in between the oil pan and the block.. the you move it slowly and try to move it around the whole pan.. and it comes off.. just be careful, DONT PRY IT, and you should be good.. use like a flimsy metal ruler or something.. thats what i did..
Old Mar 28, 2004 | 09:27 AM
pgmike's Avatar
thanks twinkie. i got the black tray off pretty easily with jsut a screwdriver but the oil pan is really annoying.
Old Mar 28, 2004 | 09:30 AM
if you have like a really thin, short knife that can work.. i had to do mine the gettoe way.. cuz my dad would only help me with tapping it.. but anything skinny/flimsy that has somewhat sharp edges will work
Old Mar 28, 2004 | 02:59 PM
sdhotwn's Avatar
Oil pans are never easy to get off.
There should actually be one bolt hole on your pan somewhere that dead ends at the block. What you do is take out all the other screws, then use one of those to screws you took out and put it into that dead end hole. Just tighten it down for a bit and it'll separate the pan for a good 6" or so. Then it's pretty easy to gently pry with a very large screw driver in small increments. Do it gently so you don't dent the pan, and it'll go from there. Shouldn't be too bad.
Later.
Steve
Old Mar 28, 2004 | 05:32 PM
pgmike's Avatar
thanks sdhottown, ill try that on tuesday since i have class and have to work all day tomo. i spent two days trying to get that crap off so this has better work.
Old Mar 30, 2004 | 09:29 AM
pgmike's Avatar
ok tried taht and now the bolt broke off in the stupid hole. im going ot try and use a tap screw to get it out. if that doesnt work im screwed.
Old Mar 30, 2004 | 09:42 AM
sdhotwn's Avatar
holy crap!!! That's a new one! Use a screw extractor to get it out. Just drill an ok starter hole into the bolt, then use a screw extractor from Sears or whatever to get it out. Should be too super hard to do.
Then try it again, use a different bolt (maybe a hardened one from Lowe's or whatever) and grease the bolt, and the tip of it when you do it, that'll help it turn easier and you won't have to worry about it seizing and snapping off again.
Let me know how it goes!
and btw, it will deform/bend the oil pan somewhat. But you can easily bend it back to shape. That is what that hole is for... plain and simple!
Later.
Old Mar 30, 2004 | 09:45 AM
pgmike's Avatar
the bolt is so thin that it makes me really nervous to try and screw nto it straight myslef so im getting my pops to do it.
this thing is pissing me off to no end, ive been workign on it since saturday mrning.
Old Mar 30, 2004 | 09:50 AM
sdhotwn's Avatar
Here you go, it's from a Mazda manual but it'll help you out a little hopefully.
Turbo's are always a long arduous process of many "little" things that cause tons of grief. Just try to find a way to not let it bother you. Best way to do that is by not having expectations... Just take your time and do what you need to do, and realize you'll hit a lot of crappy bumps!!
I'm happy to help though with anything you need.. just pm me or post here and I'll help out!
File Type: zip
