Lancer SE Suspension Swap
Old May 16, 2020 | 10:30 AM
Mikei's Avatar
Exclamation Lancer SE Suspension Swap
Hey all,
I have a 2015 Lancer SE AWC w/ 2.4L, looking for a solution here. Basically when I switch over from my winter 16" rims to 18" rims the car consistently bottoms out on medium+ bumps, all the struts have been replaced. The biggest issue I'm having is finding alternative suspension, can I put Ralliart suspension on my SE? If not, which trim is ES,GT,GTS is compatible, I can't directly find any SE suspension parts? Really don't want to replace the stock springs and have this issue again.
Thanks
Old Mar 15, 2021 | 05:18 PM
Zynone's Avatar
Works fine
I have a 2015 SE AWC and the Ralliart suspension fits fine I installed Tein coilovers that are for the Ralliart and they fit since they share the same chassis CY4A so it should go on with no problems but to answer your question I still have the issue with the car hitting the wheel well on big dips not bumps and I also installed Klutch 18's on there with 225/45 tires on there
Old Mar 15, 2021 | 05:19 PM
Zynone's Avatar
Works fine
Mikei
Nov 10, 2019 01:06 PM
tonyv13
AWD Lancer (2012 +)
Feb 26, 2019 03:49 PM
ElisionMagazine
Lancer Aftermarket Forced Induction Tech
Jul 4, 2017 02:31 PM
Helllaraw
Aug 18, 2016 05:48 PM
lancer se04
Nov 20, 2012 07:04 PM
