RC Engineering
Old Apr 20, 2004 | 08:07 AM
airlinevomitbag's Avatar
RC Engineering
Has anyone actually ordered from RC? And for those of you who have gone through the math on their site www.rceng.com what are you coming up with for sizes? 310cc seems to be too small for a TC application using their math. 370cc looks better but is a little on the large side. Im talking about 190-200 crank. I'm about to start making progress again and I dont want to spend $400 bux for the wrong stuff.
Old Apr 20, 2004 | 10:34 PM
Drive02Lancer's Avatar
well RRM boosts 6psi on stock injectors and they are fine
most upgrade to 300-330cc i believe.
but if u only wanna hit 190-200 at the CRANK u dont need injectors...RRM stage 1 is easily that at the crank...non-IC on an auto
Old Apr 20, 2004 | 11:48 PM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
Would 300-330 benefit NA engines? I am hearing that I should get larger valves if I want to really find some hp out of my car. Any idea how to go about doing that?
Old Apr 21, 2004 | 01:52 AM
i would assume better fuel management would give you more HP, allowing more fuel to flow freely...like oversized injectors/pump only working at 40% instead of the stockers workin at 80%...?? maybe
could always raise compression and get a cam gear as well, dunno about valves...that'd be tough to get bigger valves...u gotta find them..than port the valve openings EXACTLY to match the newer valves...might make the head to weak between valves though so i dunno? or do we only got 2valves/cylinder??
foxbat
Jun 1, 2016 03:02 AM
DaGermanEvo9
Dec 11, 2011 08:13 AM
DC_TypeR
Evo X Dyno Results
17
Sep 4, 2009 02:37 PM
04tarmacEVO
Jun 21, 2005 11:18 PM
