just installed my first mod
Old Jun 4, 2004 | 02:46 PM
GreenPsycho's Avatar
Talking just installed my first mod
well, i installed my very first mod to my car last night: the injen sri.
i have to say, this thing is super easy to install. i think it took me maybe 15-30 minutes for the entire thing(take old one off, put new one on) the only problem i had was that i thought they shorted me on nuts, but i found out i had to use the ones from the stock air filter box.
onto pics(click for fullsize shots):
considering how little hardware you get with the kit, i was a bit upset i spent 200 bucks on this thing. not really worth that much at all
then again, this thing sounds awesome, especially the mid range. accelaration seems a bit smoother and shifts seem smoother, but that could all be in my head.
Old Jun 4, 2004 | 02:51 PM
Blacksheepdj's Avatar
Very nice. Two notes:
Looks pointed kinda high. Make sure it isn't hitting the hood (as mine was). It will burn the sound proofing material if it's hitting.
Might want to consider an air source, as the battery blocks a lot of air flow. I'm considering running some hose from a cold air source to the filter. It would help the engine breath.
Old Jun 4, 2004 | 03:39 PM
4g94T's Avatar
really, it looks all trapped in there. maybe you should get the cf duct for your hood
Old Jun 4, 2004 | 05:54 PM
thats how its supposed to fit in, look at injen's picture they have on their site:
here
but thanks for your concern and kind comments
Old Jun 4, 2004 | 11:35 PM
4g94T's Avatar
naw i wasnt making fun of how you installed it, just suggesting to put more airflow in there because its covered by the battery
Old Jun 4, 2004 | 11:48 PM
Panther893's Avatar
ya buy a plastic duct and cut a hole in your hood like a duct the evo7 had in f&f2
Old Jun 5, 2004 | 12:29 AM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
The duct would be a perfect mod for that intake. If you really don't want a hole, you could route ducting kinda like this, but it gets dirty faster.
Old Jun 5, 2004 | 02:13 AM
ghostrider's Avatar
Congrats on the first mod! Glad to see someone else is making a functional heat shield for their SRIs. Like others have said before, all you need is some extra airflow to the filter element and you're golden.
Old Jun 5, 2004 | 02:41 AM
Panther893's Avatar
man that heat shield plus an air duct and ur in serious business
i think the air duct will force air into the intake and the heatshiled will make sort of a barrier allowing the air only one exit....the intake
Old Jun 5, 2004 | 04:22 AM
Archangelite's Avatar
hey i have the same setup, and i think it looks gorgeous and i do have the air duct from RRM, heres a pic
Old Jun 6, 2004 | 11:05 AM
majestic lancer's Avatar
just like everyone's saying, you have to get a duct to help direct more air into your intake. urbanknight's setup is the closest thing you can do to almost get as much airflow as a cai. or you could cut a hole into your injen heatshield and somehow find a way to incorporate the stock air funnel you took out from the airbox. the reason being is that although you have the heatshield already, the intake will still suffer from massive heatsoak due to the blockage of air by the battery and the fact that its a short ram. nonetheless, the performance gains are still better over stock, but you'll find it not go bog as much if you can get more airflow.. congrats on baptizing your car with its first mod
Old Jun 6, 2004 | 01:41 PM
arm07's Avatar
I got the same one except mine came with a blue filter.. I got it for 200 bucks canadian through the dealership.
Old Jun 6, 2004 | 02:20 PM
gbwaacha's Avatar
I cut a hole in my heatshield and used the stock scoop like majestic suggested...i really dont notice any difference tho...take a look at my profile for a pic..
Old Jun 6, 2004 | 03:00 PM
jsfour's Avatar
good deal...i like that cold air intake mod.
Old Jun 6, 2004 | 03:11 PM
looks nice man, i would do that if it was a good sized improvement. but you said you couldn't notice a big difference, so i'm a bit skeptical.
