Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
How Do You
Old Dec 13, 2004 | 08:13 PM
yellance's Avatar
How Do You
Install a sunpro tach meter on a 2002 oz rally.What i am really needing is how to set the shift lift any specific way or the best you can
Old Dec 14, 2004 | 10:34 AM
yellance's Avatar
So no one knows
Old Dec 14, 2004 | 10:36 AM
twardnw's Avatar
if you have the tach read the manual, that's dependent on the tach, or google search for a manual
Old Dec 14, 2004 | 10:37 AM
Alchemist's Avatar
tap into 12v power, ground and the RPM wire. Setting the shift light depends on how the pod is programmed. does it use a wheel type adjuster? An RPM pod? is it completely preset? That's how you'll set it (or not if it's not adjustable)
don't have a wiring diagram handy.... they're on here, just search
Old Dec 14, 2004 | 10:38 AM
twardnw's Avatar
here ya go, did the work for you
http://www.tradervar.com/All%20Other%20Sun%20Tachs.pdf
Old Dec 14, 2004 | 10:46 AM
Alchemist's Avatar
nice work!
Old Dec 14, 2004 | 10:49 AM
yellance's Avatar
that is the wrong diagram but thanks.Engineer boy it is on/off switches and i actually just found the diagram but it does not say how to set the shift light which was my question plus a friend had given it to me so it is set for a crx so i have to reset it
TxFAkuma
Past Winners / Entries
May 13, 2016 02:18 PM
anton406
Oct 16, 2008 09:23 AM
neyugn_naut
Apr 12, 2005 05:54 AM
