Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Help on Trouble shooting Power Window
Old Sep 5, 2005 | 10:56 AM
Genx007's Avatar
Hi all, I got my 2003 OZ (second hand) recently and the left rear window does not roll down. The window does not respond to the switch on the driver's side. I replaced the rear switch because it was broken but no help. Now I still have to inspect the regulator and I'm hoping it's not the motor (expensive to replace).
Anyone know where the wiring harness is located for this window?
I don't think it's there's anything wrong with the front switch because it can control the other three windows.
Any thoughts? Thanks in advance.
Old Sep 5, 2005 | 11:58 AM
twardnw's Avatar
I'd pull the door panel off and check to see if there is any power getting to the motor when you activate the switch. If there is no power, you can trace the wires to see if there is a break somewhere, and if there is power, then it's going to be the motor
Old Sep 7, 2005 | 06:06 AM
Genx007's Avatar
Thanks...I'll let you know what happens. Mitsu here in Toronto is charging me almost $300 just for the motor. Rip off!
Old Sep 7, 2005 | 06:07 AM
Genx007's Avatar
oops...icons went in the wrong spot... .oO0 What a newb 0Oo.
Old Oct 10, 2005 | 12:51 PM
Grnd0Lancer's Avatar
did you check the fuse first ? a couple weeks ago my rear driver side didn't work but all the others did... i checked the fuse and it was i guess partially blown... it's a big pink one in the engine bay.... maybe it's multiple fuse thingy and it might have 4 built into it (one for each window.... i bought a new one at auto zone and the window worked fine.... hope that helps some...
