Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
How to Install tachometer
Old Nov 30, 2006 | 11:47 PM
actafool2f's Avatar
i got a 5" 4 in 1 tacometer i got all the wires conected but green. the green wire from the tachometer is supposed to go to tach terminal which i have no idea where its at. can anyone help me i have 2002 lancer oz. i hear that you can find tach signal on the ecu but i dont know which pin # it is. can anyone help me?
Old Dec 1, 2006 | 08:18 PM
actafool2f's Avatar
can i wire the aftermarket tachometer wire to the one i already have, if yes which wire is it. i took apart the gauge cluster and there is like 10,15 wires there if anybody knows which ne is it that will get signal to my aftermarket gauge.
Old Dec 1, 2006 | 08:34 PM
mitsuozboi's Avatar
I think ive only seen one in a lancer. Thats why your not getting responses. no one knows. lol. you arnt able to just trace the wire behind the gauge to where it goes?
Old Dec 2, 2006 | 01:04 AM
actafool2f's Avatar
yea i dont know where they go what they are for. i tried a few wires and nothing. what i'll do is try every single one, and i hope i'll get something.
Old Dec 2, 2006 | 03:31 PM
phil_'s Avatar
I had to wire in a tach signal and I used the green wire (if I remember correctly) on the right hand connector. It was the wire in the center of the plug.
(edit- Its the green wire, pin 11, on the C-01 plug on the back of the cluster(the plug that is to the rightmost side if you are looking at the back of the cluster))
Old Dec 2, 2006 | 05:07 PM
actafool2f's Avatar
ok i pluged it with the pin 11 i cut it and conected it with both ends. but nothing the tach didnt even move. i dono what to do its pissin me off now.
Old Dec 2, 2006 | 08:40 PM
Grey_Fox's Avatar
Have you tried to contact the manufacturer and ask them questions about it?
-Grey_Fox
Old Dec 5, 2006 | 11:31 AM
actafool2f's Avatar
yes i did and they sed they know nothing about it they just sell it. i got it off ebay.
Old Dec 5, 2006 | 11:51 AM
Grey_Fox's Avatar
Is it one of those generic Ebay products? Thought you got someone thing like a new or used Auto Meter.
Might not be able to help. Sound like you were talking to the wholesaler.
What's the link to the auction you won?
Does it look something like these?
"REAL CARBON FIBER"
If worst comes to worst you would have to take it to a performance/speed shop and pay them to install it; someone at autozone might be able to help
OR
Might not be able to install it at all.
-Grey_Fox
Old Dec 5, 2006 | 02:20 PM
phil_'s Avatar
there is also an rpm signal wire at the ECU. On connector C-117 (This is the connector at the ECU w/ 12 pins.), it is the green/white wire. This is the engine speed detection sensor. The ecu engine speed sensor signal is the one i use for my MS2 and zeitronix, it works beautifully.
If that doesn't work your last option would be to try the Crankshaft pos. sensor. On connector C-115(connector w/ 22 pins), it's the brown/green wire.
Or you could try a coilpack trigger signal. This option may only give you a 1/2 rpm reading if you are only reading off one coil.
Goodluck
Old Dec 5, 2006 | 02:58 PM
atilla's Avatar
you can compare your ECU to that of an evo VIII but i believe the pinout is different. i think our ECUs match up with a VII instead. i'm not %100 on this, but it will at least give you a rough idea. don't go chopping up wires on your ECU unless you're %100 sure about it.
Old Dec 5, 2006 | 10:30 PM
actafool2f's Avatar
i just tried wiring it up to the ecu green wire on the 12 pin conncetor it didnt work, my piggy back system is also connected to the green white wire could that be the wire for engine speed, would it not let the tach work?
Old Dec 5, 2006 | 11:08 PM
actafool2f's Avatar
i also tried the crankshaft pos. sensor and it didnt work, im begining to think that its something with the tach. anybody have any other ideas what to do. im going to take it to performance shop and if it doesent work then its the tach.
Old Dec 5, 2006 | 11:10 PM
actafool2f's Avatar
hey phil what kind of lancer did u instal the MS2 and zeitronix. is it the 02 lancer oz or 02+ if not then its not the same wires on the ecu.
Old Dec 7, 2006 | 05:48 AM
phil_'s Avatar
Install was done on an 03'. But the manual I got the information from states it pertains to both 2002-2003.
Have you tried the green/white wire your piggy is connected to? Tapping it shouldn't disrupt any signal at your stock tach nor the piggyback.
