Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Door Panel Removal/Aftermarket Speaker Mounting discussion
Old Aug 27, 2008 | 08:59 AM
sna08's Avatar
yeah the pics arent' working for me either.... what's our mounting depth? that's what i wanna know
Old Aug 27, 2008 | 10:54 PM
Prodigal's Avatar
I put rockford P162S mids in the doors (here's some pics) and there was more than enough clearance around the back. Go to the RF website and get the mounting depth of those speakers and you can get an idea.
Old Sep 16, 2008 | 07:34 PM
Elvis077's Avatar
I am making door pods for my t162 rockford speakers. that gives about 3-4 inches of depth. bad pictures but you get the idea.
Attached Thumbnails Door Panel Removal/Aftermarket Speaker Mounting discussion-pod1.jpg   Door Panel Removal/Aftermarket Speaker Mounting discussion-pod2.jpg
Old Sep 16, 2008 | 10:53 PM
Prodigal's Avatar
Nice job man! Is that done by fibreglass or what?
Old Sep 16, 2008 | 11:37 PM
Elvis077's Avatar
Yeah.. Some fiberglass, bondo and some mdf for the ring.
Old Sep 26, 2008 | 11:54 PM
Elvis077's Avatar
scratch that other stuff.. here's how it should be.
Attached Thumbnails Door Panel Removal/Aftermarket Speaker Mounting discussion-pod1.jpg   Door Panel Removal/Aftermarket Speaker Mounting discussion-pod2.jpg   Door Panel Removal/Aftermarket Speaker Mounting discussion-pod3.jpg
Old Jan 16, 2009 | 10:53 AM
orsabv31's Avatar
not picture
Old Jan 16, 2009 | 05:53 PM
Stuntfly02's Avatar
too much red, but the enclosures look great
Old Mar 15, 2009 | 08:19 PM
humblehyper's Avatar
Doesn't anyone have any how-to guide with pictures? I have an 09 Lancer GTS if I replace the stock speaker will I still be able to use the stock tweeters? Or I need a new set of component speakers?
Willl I get more highs by replacing the stock? Or I need to install an amplifier to get this? Thanks much.
Old Mar 17, 2009 | 09:07 AM
RGarant's Avatar
and can you just buy rf speakers for the doors that will work with the one they give in the sun and sound package
Old Mar 17, 2009 | 09:27 PM
Thanks.
Old May 6, 2009 | 09:32 PM
Sparx123's Avatar
How did you get the fiberglass to stick to the plastic your speaker mounts seem to be the best way to do a speaker install...
Old Aug 11, 2009 | 09:15 PM
Does any have a detailed instructions with pictures on how to replace the front and back stock speakers? And does the 09 GTS have a separate crossover box for the front speakers? Thanks.
Old Aug 15, 2009 | 05:11 PM
SL33P3R's Avatar
I noticed there are no specs on which speaker wires are positive or negative. There are yellow and green? Which one is which dudes?
Old Aug 16, 2009 | 01:23 PM
yitzac1990's Avatar
heres an easy test. get a 9v battery and 2 spare wires to attach to the 9v battery. touch the positive wire from the battery to one wire going to the speaker, and the negative battery wire to the other wire for the speaker. the speaker will "pop." if the speaker "pops" outward (away from magnet), then that means the wires are hooked up correctly, and the wire that is connected to the positive on the battery IS the speakers positive, and negative on the battery IS the negative speaker wire. if the speaker "pops" inward (toward the magnet), reverse the wires, and now you know which wire is positive and which is negative. this works for all speakers pretty much.
