Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Headlights
Old Mar 10, 2008 | 05:13 PM
dbreault's Avatar
Headlights
How do you get into your headlights to change the bulb inside?
Old Mar 10, 2008 | 06:24 PM
SLVROZ_03's Avatar
There's a ring around the bulb harness that you turn counterclockwise I believe. Then taking a flathead screwdriver carefully pry the harness off of the bulb. The harness has a clip to hold it on the bulb...so you'll have to hold that down while prying it off. After the harness is removed, the bulb should come right out!
Old Mar 11, 2008 | 09:47 PM
dbreault's Avatar
okay but how do you take apart the headlights?
Old Mar 11, 2008 | 09:51 PM
SilverShadow03's Avatar
you bake them in the oven and carefully pry them apart......there's a thread showing you how to do it......but you don't need to in order to replace the bulb.
Old Mar 12, 2008 | 04:51 AM
Kurt's Avatar
Clicky the linky and it will tell you everything that you need. This is the instructions that I used when I painted my housings three years ago.
