Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
How-To: VG Install..
Old Apr 29, 2007 | 07:32 PM
Kid Lancer 7's Avatar
Originally Posted by BensLancer
I'm not gonna worry about mine right now! I'm just gonna let the bodyshop guys put it on after the new paint job!
ben never wants to get his hands dirty lol ...... just busting ur chops bro
Old Jun 14, 2007 | 08:43 PM
JRR's Avatar
JRR
is that the same one thats on the evo mr? and where did u find that, cause i want one!
Old Jun 14, 2007 | 09:22 PM
Blacksheepdj's Avatar
Yes, it's the same as the Evo MR. There's only one type of VG on the market, no matter what vendor you choose.
One again, READ. He got it from Rexspeed, as he said in the first post...
Old Jun 14, 2007 | 10:04 PM
crfdude86's Avatar
great instructions. Thanks a lot
Old Jun 15, 2007 | 03:16 AM
EVOIXMR8916's Avatar
lol mph^^^^
Old Sep 24, 2007 | 02:45 PM
lancer02es's Avatar
vortec generator
what the heck is a vortec generator ? what are thr benefits of it ?
Originally Posted by CadiLuva
heres another easy How-To on installing a Vortex Generator.. i personally used the Rexspeed version..
ok pop the trunk.. and start by removing the weather stripping.. be very careful not to bend it.. you only need to unclip it as far as where the VG will go.. remove any and all debris.. grab some paper towels and i used windex.. it degreases all surfaces pretty well.. and wipe/scrub the roof right where the VG goes.. then wipe down the inside of the VG as well.. allow about 5 minutes to ensure the surface is dry.. apply the antennae clip.. be advised it may rust.. rust proof paint is suggested.. apply the 3M tape in the same shape/pattern as recommended by Rexspeed himself.. rub the 3M tape down real well to ensure it is glued onto the VG.. at this point i removed all the extra film from the 3M tape.. i had my wife place the VG under the weather stripping on her side while maintaining it elevated so the tape wouldnt catch.. i had her align the VG with the backglass moulding and set it down.. once it was under both sides of the weather stripping and aligned on the backglass moulding your DONE.. continue to rub the VG down right where the 3M tape is placed..
Old Sep 24, 2007 | 02:51 PM
mitsuozboi's Avatar
Basically.... it creates a vortex by splitting the air. which in turn makes the air travel down the rear window rather then across the rear of the car. It works directly with a evo wing and when used with the wing creates more downforce. If you want more info or windtunnel test charts.. do some searchin. they are around.
Old Oct 14, 2007 | 04:20 PM
icecube172's Avatar
i got my VG and got it painted too, it's ready to go on but i don't know how to remove the weather strip. anyone knows how please post a note or even better some pics plz. thanks
Old Oct 21, 2007 | 07:35 PM
elaina's Avatar
ya except you need to be going like 100 mph if `m not msitaken.
Old Oct 21, 2007 | 07:38 PM
mitsuozboi's Avatar
You start at the trunk and pull up carefully. there are a bunch of plastic clips that hold it on. I broke a couple of them taking it off. I wasnt careful enouph. lol. It went back fine and hasnt been an issue.
But yeah.... You basically start at the trunk and pull it up till you get passed where the VG sits.
yeah. Almost top speed on the lancer before it gets effective. lol
Old Mar 14, 2008 | 01:02 AM
aznracer13's Avatar
this will fit lancer es right
Old Mar 14, 2008 | 07:29 AM
*Zero*'s Avatar
^^^ yes, it will fit pretty much all lancers 02-06...dunno about the newer ones
Old Mar 14, 2008 | 09:07 AM
Won't fit the 2008s. Our roof is about 2" wider. And the contour might not be the same. Antenna is definitely different as well...
Old Mar 25, 2008 | 01:27 PM
ericxd's Avatar
what does the above even mean?
Old Mar 26, 2008 | 01:24 AM
mstove's Avatar
In the original post, immediately before the above statement, the post read "apply the antennae clip". So if you put it together it says "apply the antennae clip.. be advised it may rust.. rust proof paint is suggested.."
Maybe I'm grasping at straws here, but I think the intention was to convey the possibility that the antennae clip might be susceptible to deterioration and/or corrosion in the form of rust. That being the case, it is suggested that a rust proof paint (such as Rust-Oleum) be used to coat the antenna clip in an effort to protect the clip from corrosion...such as rust.
Hopefully this has helped to clear things up a bit.
