Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
help with clutch
Old Apr 3, 2008 | 06:21 PM
jonny2086's Avatar
Question help with clutch
has anyone changed their clutch...........if so is it hard to do and if anyone can give me some guidance on how to do it.........thanks
Old Apr 3, 2008 | 06:46 PM
Myszkewicz's Avatar
Not saying this is you, but I wouldn't recommend a clutch swap to someone who can't do basics like brakes, belts, oil, and filters. Also, there are quite often special tools required (sometimes other tools can do in a pinch) for removing/installing drive train parts.
How much wrench-turning experience do you have, and how extensive is your tool collection? Do you have a back-up plan in case the car doesn't put itself back together correctly? Lacking any of those should weigh in heavily toward having it done, rather than DIY.
Old Apr 4, 2008 | 01:20 PM
jonny2086's Avatar
thanks but i have alot of tool and some knowlage about working on cars just not too sure about the sepacle ones that are needed and process of clutch installation................this will be my first time so i hope it works.............
