How to change spark plugs on a 2005 Lancer
I went to check all the threads about this but it seems that it doesn't have the link anymore. I hope someone can post it again please. Thanks for your help.
first, disconnect your negative battery terminal... and then...
take off the spark plug wires(the rubber things going into your valve cover).. you need a spark plug socket.. probably 13/16ths that has that lil rubber thing/holder inside.. you can get it from any auto store pretty much.. then you need the ratchet for the socket and lefty loosy, righty tighty! take out the old ones... put in new ones.. do opposite procedure... done... voila! hahha
