Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
headlight alignment
Old Jun 17, 2008 | 09:34 PM
jappaswat's Avatar
headlight alignment
has anybody figured out how to align the headlights?
i just installed HIDs and i really dont want to blind other drivers (and it looks very tacky to me when the car is glaring).
i guess can take it to mitsubishi and get it fixed but i love DIYs
Old Jun 17, 2008 | 09:48 PM
streamline808's Avatar
theres two ways you can do it. first is use a 6" phillips screw driver to reach down an alley on the headlight assembly to turn the adjustment dial(see pic)
or if you look at the bracket that mounts the harness for your lights you should see a 10mm bolt that you can use a socket and ratchet to trun it. dont got the pic for that one right now but if you cant find it and need the pic let me know
Old Jun 18, 2008 | 09:12 AM
MasterAK's Avatar
Look at the attachment for instructions.
Good luck.
Old Jun 18, 2008 | 09:17 AM
MasterAK's Avatar
do you mean the bolt that holds the entire headlight assembly?
Old Jun 18, 2008 | 08:44 PM
jappaswat's Avatar
wow guys thanks for the quick response. this is awesome and i can now use my HIDs responsibly!
evom.net ftw
Old Jun 19, 2008 | 03:26 PM
empire4vr's Avatar
Have you tried to adjust them yet? I want to do the same thing but I figured I would wait to see if it even helps before I do it. Let me know how it goes. Thanks!
Old Jun 22, 2008 | 07:08 PM
jappaswat's Avatar
yea i tried; i failed using the philips screw method cuz i can't find a 6inch driver that's thin enough to fit through the gap.
the bolt works well tho (to find the bolt, just look through the alley and the first bolt you see is the adjustment bolt)
turn clockwise (your direction, facing headlamp) and you will raise it vertically. turn counter clockwise and it will lower vertically.
i used a wrench to turn the bolt and with limited space it took me a while. but after a few turns you will see a significant lowering. i dont blind people anymore. perfect.
Old Jun 23, 2008 | 03:03 PM
empire4vr's Avatar
Sweet! Thanks man, I'll give it a shot.
Old Sep 12, 2008 | 02:00 PM
WIREBLADE's Avatar
Is there any chance that the High Beam can be adjust also coz my Low Beam is already good but then my Low Beam was way too high! Thanks alot!
Old Sep 26, 2008 | 11:56 PM
wsquare's Avatar
i adjusted it vertically but now both of the lights r aiming toward to right side (horzontally) ...it's weird...so does any of u guys know how to adjust it bak to the left? thanks!
shLa11
Oct 21, 2012 06:28 AM
IdahoRally
Lancer Troubleshooting
Feb 20, 2010 12:20 PM
DVDee
Northeast Region
Feb 10, 2010 11:33 AM
EricLoveYouMost
West Region
Apr 10, 2008 05:11 PM
LanEvoNine
Northeast Region
Oct 12, 2006 06:22 PM
