Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
HELP on how to change my oil!!!
Old Jun 4, 2009 | 02:43 PM
Princess*Lancer's Avatar
Question HELP on how to change my oil!!!
I am new to the forum and im looking for some help. I have a black 08 lancer gts and have decided its time for me to save money and learn to change my own oil!!! Please break it down for me including what oil and filter to buy because im honestly clueless!!!
Thanks!!!!!!!
Old Jun 4, 2009 | 02:48 PM
Jeff1121's Avatar
im guessing there is a thread on this in the DYI section
Old Jun 4, 2009 | 03:11 PM
dustyp34's Avatar
Oil: 5w20 synthetic or conventional. most go with synthetic and some have said that once you go synthetic you cant go back to conventional which is total BS.
Oil Brand: its really up to you I usually use valvoline or castrol
Oil Filter: dont remember the numbers on it but you can look it up in the oil/air filter book in the store or have someone look it up on the computer.
Process: first you start by placing an oil bucket or whatever you are going to use to drain the oil into. Unscrew the oil plug from the oil pan( the oil pan is located on the passenger side just about directly under the floorboard you cant miss it the plug is facing the rear of the car) once you remove the plug clean the plug with a paper towel or rag whichever you choose. let the oil drain until it stops.
Next: remove the oil filter which is almost directly infront of the oil pan a little closer to the front of the engine. once removed let the oil drain from there. once it is finish clean off all the oil from the seal and threads.
Next: replace the oil plug back into the oil pan securing tightly. now onto the filter place a thin layer of new oil onto the rubber seal of the filter and screw back on( caution: do not over tighten the filter cause as the seal heats up it becomes a greater seal and over tightning will cause it to be hard as hell to get off the next time)
Next: fill with whatever brand of oil you choose as long as it is 5w20. takes 4.2 quarts.
Finally: after you have the oil filled crank the car and let it run for a few min and turn off. let the oil settle for a few and check the oil level (just to ensure that you have filled it properly)
Thats the process.
Just a tip you can warm the car up a little and the oil will drain faster.
Old Jun 4, 2009 | 03:16 PM
thanks
Old Jun 4, 2009 | 03:37 PM
Stuntfly02's Avatar
I recomend pouring about half a quart directly into your filter. Remember people the Oil amounts with and without filter are very important. it says like 4.2 quarts w/o filter and 4.5 w/ filter if im not mistaken.
Old Jun 5, 2009 | 04:40 AM
kalpakiotis's Avatar
If you care to do so, I always use engine flush when I do my oil changes. Most people will say you dont need it, but it wont hurt, and itll keep your engine cleaner.
Old Jun 5, 2009 | 05:59 AM
Thanks, what product to you use for this?
Old Jun 8, 2009 | 04:18 AM
not sure what its called lol
but if u go by all the chemical stuff in the back of an auto zone or advance auto parts, theres a small silver can that holds like half a litter maybe and itll say engine flush on it. Should only be a few buxs.
Old Jun 8, 2009 | 10:23 AM
planetasia415's Avatar
There's a how to by blacksheep. o.O
Old Jun 12, 2009 | 05:27 AM
CGroovy2k2's Avatar
Check out the AMSoil website. It will give you the types of oil needed for your vehicle and the capacities.
coryo93
Dec 7, 2015 06:42 PM
JustAnoterEvo
Evo X How Tos / Installations
13
Jul 3, 2013 04:41 PM
campbmic
Mar 27, 2011 10:23 PM
evo4sho
23
Jul 11, 2010 11:19 PM
MIT5U ES
Jul 29, 2007 10:56 AM
