Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Amp acting strange.
Old Dec 28, 2009 | 10:29 PM
thereaperishere's Avatar
Amp acting strange.
Hey everybody! New guy here. I just installed an amp and subwoofer in my 09 GTS with the use of a LOC. I connected it to the wires that are in the pillar next to the drivers side door. The sound comes through fine but whenever I turn the car off, the subwoofer will give off a thud. The amp will "trip" whenever I use the power door locks and I have to turn the car off and then on again to get the amp to turn back on. The wires that I spliced into were the pink and torquoise. Anybody have any idea whats going on? Maybe I didnt splice into the correct wires? Any help would be greatly appreciated.
Old Dec 29, 2009 | 01:11 PM
yitzac1990's Avatar
lol wow man you have to connect the LOC to audio wires, not power and ground.....hopefully you didnt fry the LOC
Old Dec 29, 2009 | 03:10 PM
Its connected to the audio wires in the pillar by the drivers seat. Not sure what your saying. Anyways, I got everything sorted out. I adjusted the crossover on the amp and all is well. The sound to the sub comes out perfectly and no more popping when i turn the car off or use the door locks.
Old Dec 29, 2009 | 09:25 PM
yitzac1990's Avatar
ohhhh that pillar haha.....do you mean like when you push "lock" or "unlock" it makes a thump? and when you shut your car off it makes a thump too?
Old Dec 29, 2009 | 09:57 PM
kmc8302's Avatar
i have a whole post on which wires go to what.
https://www.evolutionm.net/forums/la...4-install.html
Old Dec 30, 2009 | 01:09 AM
Exactly. I thought that I had things sorted out but I just went out for a drive and tried the "unlock" and it made a thump again only this time it wasnt hard enough to make the amp go into "protect" mode. When I got home and turned the car off it made the thump also. This is getting frustrating.
Nevermind, the problem was the wires that I hooked the LOC to. The gray with blue stripe one should have been where the turqoise one was hooked up to the LOC. Switched the wires and everything works. I dont know why the "how to" that I looked up specified the yellow and turqoise wires when it should have been yellow and gray w/blue stripe?
Last edited by thereaperishere; Dec 31, 2009 at 07:25 PM. Reason: Found the solution
