Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Megan Coilovers Settings?
Old Jul 19, 2010 | 01:26 AM
Defcon5Es's Avatar
I installed my coils on my gts last week and i'm wondering what camber,toe,caster settings should i do? I want to tackle corners smoothly without worrying about my tires wearing out. Any suggestions? This is mainly for "dd" mountain/street setup. Thank You.
P.s.
Damper is already set up to 23 Front and 17 Rear.
Old Jul 19, 2010 | 04:46 AM
kalpakiotis's Avatar
In the front I have ~1.5 degree of camber and the rear is ~2. Note that you can't adjust the rear camber. Rotating tires around I don't see any uneven wear. The toe I have set close to 0...unless you are racing, I personally don't see the point of adjusting the toe to gain a little bit of traction, especially since as a DD you spend most of your time going straight. As for dampening, i have mine around 15 in front and 18 in the back.
