Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
power locks
Old May 3, 2011 | 01:03 PM
lancah23's Avatar
Exclamation power locks
Hey everyone, i bought a lancer DE which came with nothing such as A/C or power locks. I opened the drivers side door panel and found out that the actuators were built into the latch and the wiring was all there. the only thing was the switch. so i managed to get a switch but the new switch is from an 09 lancer gts and wont fit the connector that came with the 08 lancer DE door wire harness. i went to the dealership, only thing is its kind of expensive. I plan on sodering the wires directly to the pin. but i dont know what each pin is for. if anyone could help/ give me advice on how to do this it would be greatly appreciated. the part number for the door switch is 8608A068.
Old Jun 22, 2011 | 07:12 PM
dpompeo's Avatar
hey man i wanted to see if anything ever came of this.
Old Jun 22, 2011 | 08:54 PM
ninjacoco's Avatar
Balls of Steel
I wonder if a switch from an ES would've fit?
Old Jun 23, 2011 | 03:23 PM
dpompeo's Avatar
the problem is the control from an ES, GTS, Evo, etc. doesn't fit the plug from the DE. so adding the switch wouldn't work as the whole control is one piece. it includes the window control and mirror controls
Old Jun 25, 2011 | 12:03 AM
lancah23's Avatar
i actually did some research on it and it seems that the old control unit from the older lancers seems to have the same pin connector. not sure though still looking around.
Old Jun 25, 2011 | 08:12 PM
dpompeo's Avatar
man I bought an evo unit with the wire harness attached. they cut the wires about 8 inches down. now if only i can find out which wires go where. lol
