Double din frame for aftermarket stereo on 2015 ES
I have a 2015 Lancer ES and I've been interested in getting a Kenwood 7" touchscreen deck. Has anyone found any frames to fit aftermarket decks? The opening in my car is too wide for most aftermarket stereos, it's designed to fit touchscreen decks provided by Mitsubishi.
You will also require a wiring harness which is about $20. If the double din deck you have is a standard size it should fit no problem, if you go with a no name from china or something like that you will need to slightly modify the dash kit.
Jeff
FS[Northeast]: Pioneer Avic Z110bt double din + evo8/9 double din faceplate
Evo8yu
Sep 11, 2014 09:56 AM
elecan
Evo X How Tos / Installations
Oct 10, 2013 02:08 PM
elecan
Jul 14, 2013 11:31 AM
