Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
My 03 mistu OZ Rally
Old Jul 8, 2015 | 07:39 PM
DarkVoid88's Avatar
I recently got a oz rally parts car an was gonna fix it up as daily driver but I don't know where to look for JDM 4G63 engine that's respectable any help would be appreciated thank you
Old Jul 10, 2015 | 08:42 PM
CrAnSwIcK's Avatar
for a daily driver why do you need a 4G63...the 4G94 can handle a little bit of boost...
Old Jul 14, 2015 | 04:24 PM
DarkVoid88's Avatar
ok well do you know where i could get a 4G94? plus i failed to mention that the engine in it is trashed or is there any other engine i could throw in it
Old Jul 15, 2015 | 12:47 PM
jakermeister's Avatar
02-07 es/oz lancers have the 4g94. The 02-03 lancers have a returned fuel system (unused fuel returns to the fuel tank) and the 04-07 have a returnless (fuel goes to the fuel rail and never returns to the tank). The 02-03 lancers also have a internal slave on the transmission. The 04-07 have a external slave. Other than cosmetic stuff that's the only difference between the years The interiors are completely the same.
As for a 4g63 you'll need to be able to fab up some parts to make it work as well as swap some transmission parts.
If its going to be a daily driver just drop a used engine in and be done with it....... maybe a new stereo and call it quits. It takes a lot of time to boost and tune which could also give you problems if your car is a DD.
Old Jul 16, 2015 | 06:31 PM
CrAnSwIcK's Avatar
yeah engine swapping to a 63 would require you pulling the engine control harness out and replacing it with one from an Evo, as well as the ECU, on top of the custom engine mount fabrication, and transmission fitting issues that was mentioned already...
Old Jul 21, 2015 | 09:36 AM
SilentCool's Avatar
How soon do you need the car up and running? That swap will take quite a bit of cash & time. Also, as mentioned before quite a bit of fabricating.
Don't get me wrong if you have the time and money then I say go for it, do what you want, it's your car but it's no Honda so parts are not in abundance and swaps are not as simple.
WKM Jim
Mid-Atlantic Region
Jul 2, 2003 02:16 PM
HighWayDrifter
Apr 11, 2003 07:16 PM
dw1784
Jan 3, 2003 05:34 AM
Magister
May 29, 2002 07:13 PM
