08 and 06 RA suspension the same?
ok here in PR the stores are selling the springs for my lancer 08 and they say that the suspension of the lancer rally art form 2006 its the same is this true or should I wait until the suspension for my lancer arrives ?? because in the stores they say its the same fit and would do the same thing of course they are selling TEIN springs they drop 2.2 " thats a lot!! but would they be recommended?:mitsu:
I dunno about that. I'd just buy some RRMs, but that's just me.
It'd be really cool if the 08 suspension was RA suspension, because that would open up a lot of possibilities. |
yeah I know man but the problem should be maybe the weight of the car both suspensions cant handle the same weight .. wright?
Supposed to be new from the ground up.
nothing is ever new from the ground up. i really think this should be investigated.
if someone went around and investigated all the possible compatibilities for parts made for past lancers and the 08s, i bet we'd have 30 more hp than we do presently. for a lot less than brand new barely tested RRM products as well. |
Guarantee you Rock could answer this right away. I mean his team designed the new ones so he should know whether they are the same as the RA ones... Maybe PM him and post his reply to you.
Originally Posted by cthagreekgod
(Post 4567915)
get the part numbers for the ralliart shocks, and compare with the part # for the 08 shocks
I can tell you wright now the suspensions are totally different I had an 04 RA and It for sure didnt have MacPherson struts in the front or independent multi-link in the rear. And yes this car is new from the ground up there will not be any compatible parts from the ECU to the drivetrain. Every thing about this car is different then the old gen's but does have some common factors with the outlander.
Originally Posted by show time
(Post 4568650)
lowering spring
Originally Posted by GTS08
(Post 4537756)
Originally Posted by gatzaraki
(Post 4595653)
flaco el distribuidor de progress en pr me dijo lo mismo pero que salian chiriando,asi que no te tomes el chance o si lo haces me dejas saber
