Backup camera install - Reverse sensor wire
Hi.
I'm trying to install an aftermarket backup camera to an aftermarket stereo, the problem is i need to connect the stereo´s reverse sensor wire but i cannot find the correct cable on my lancer dashboard. Is it there a cable on the dashboard that can be used for these instead of wiring a cable from the front to the back of the car. I´ve read many post but no one seems to explain it at all. |
there is none you must connect it as the diagram says
https://cimg3.ibsrv.net/gimg/www.evo...e93fdbe36f.jpg |
The wiring that comes with the camera doesnt have the red wire.
I already found a solution. Just wired to the white cable going on the drivers side door panel, the wire that goes tho the trunk. From there to the stereo and it works. |
