Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Backup camera install - Reverse sensor wire
Old Jan 21, 2019 | 10:19 PM
Revajeer's Avatar
Hi.
I'm trying to install an aftermarket backup camera to an aftermarket stereo, the problem is i need to connect the stereo´s reverse sensor wire but i cannot find the correct cable on my lancer dashboard.
Is it there a cable on the dashboard that can be used for these instead of wiring a cable from the front to the back of the car.
I´ve read many post but no one seems to explain it at all.
Old Feb 11, 2019 | 06:16 PM
michael2014's Avatar
there is none you must connect it as the diagram says
Old Feb 12, 2019 | 11:35 AM
Revajeer's Avatar
The wiring that comes with the camera doesnt have the red wire.
I already found a solution.
Just wired to the white cable going on the drivers side door panel, the wire that goes tho the trunk.
From there to the stereo and it works.
