Lancer-Mirage Compatibility Forum For parts that can be used on both Lancer & Mirage models, post/look in here.
4g93 pulleys for 4g94 lancer
Old Jun 28, 2006 | 08:21 AM
  #61
comatose721's Avatar
Originally Posted by B-SR
Thanks for trying it out!
it was an interesting experience. i'm glad i was one of the earlier ones to toy around with it
Old Jun 28, 2006 | 03:12 PM
  #62
Evo666's Avatar
so the silver one is some crap off ebay?
Old Jun 28, 2006 | 03:28 PM
  #63
Alchemist's Avatar
I think the large silver one is the RRM lightweight pulley. But thanks for driving over to Lancerland to play our game... your shuttle to Evoville is waiting.
Old Jun 28, 2006 | 04:07 PM
  #64
it's the RRM pulley
Old Jun 28, 2006 | 05:13 PM
  #65
REVIEW:
ok ok ok so here is what you all have been waiting for
let's start off with the pulley itself. i used an Unorthodox Ultra S Underdrive Pulley for a 5g Mirage (#
020910702). it is LIGHTER than the RRM pulley and exceptionally different in size (smaller; obviously). you can find the pulley at the following locations:
www.visionimports.com
www.unorthodoxracing.com
i'm sure there are other places you can find them. if you want to go elsewhere; i will let you do your own searching. i bought mine, legit, off of ebay for a few $$$ cheaper than the shelf price. you can also find many other knock-off brand pulleys that have been discussed on the mirage boards. i have read that they work just as good.
Unorthodox (red), RRM (silver), and OEM (black) pulley.
notice a difference in size?
belts. here's how i did it. bought crappy OEM belts before the install. i swapped the UDP for the RRM pulley and reset the tensioners with the OEM belts. then i cut each belt to what would be a proper fit, then i took it back to the store. the helpful attendant measured them and we found some belts that matched that length. both belts were around 1-2 inches shorter than OEM spec. here are the part numbers:
Drive Belt # 5050490-5PK1245
Alternator #5040285-4PK0725
go about the installation the same as you would with the RRM pulley (i misplaced my sheet they sent with my pulley. i'm sure you can find them on here somewhere....likely here: RRM Crank Pulley Installed)
after the install everything ran normal. i had a clean start, normal idle, etc. throttle response is more noticable than the RRM pulley. the engine rev's noticably faster than the RRM pulley as well.
compared to the lightweight pulley: power difference starts to kick in around 3300rpm's, however the most noticable gains are found between 3900-redline. the car pulls harder; both sooner AND longer. powerband is beautiful. it feels as though the TRQ #'s made a welcome increase
here are 2 more pictures of the pulley installed:
https://www.evolutionm.net/forums/at...chmentid=92515
https://www.evolutionm.net/forums/at...chmentid=92516
so far i haven't run into any issues with the pulley. i would be happy to answer any other questions that anybody has to put on the table. i just feel great knowing i finally pulled this thing off
...i think that just about covers everything...
mark
Old Jun 28, 2006 | 05:31 PM
  #66
Evo666's Avatar
Uh im not an evo, a fellow mirage trying to help you guys out.
also those belt number matched my numbers i gave you guys so you could of saved some time there to read my post. And since its the same belt number you guys can use Procarparts pulley to save more money.
It's good to see parts off the mirage fits the lancer as i've used some parts from you guys.
Old Jun 28, 2006 | 06:02 PM
  #67
i was informed that the mirage belts would not fit due to different accesories and such. thanks for the input though. i wasn't out to buy a belt i wasn't sure whether or not it would fit.
Old Jun 28, 2006 | 06:48 PM
  #68
Evo666's Avatar
thats cool, how much was the Unorthodox pulley?
Old Jun 28, 2006 | 07:01 PM
  #69
Alchemist's Avatar
Comatose: are those dayco belts? I couldn't find them using the enitre number but the part before the "-" brings up a 5 rib and 4 rib belt respectively. Do you by chance have the lengths?
Thanks for the update- good work
Old Jun 28, 2006 | 07:13 PM
  #70
it's marketed at $184.95; i paid about $145
those 2 numbers were both written seperatly on each box. the drive belt is a Dayco Poly-Cog Gold Label belt. the generator belt is a plain old Dayco. i am not certain on belt length. i think the guy measured 28.5in on the drive belt though. however, i am not certain
mark
Old Jul 22, 2006 | 01:04 AM
  #71
Alchemist's Avatar
mid project update....
Tuesday night: torque wrench with extensions. No good. I weigh about 300# and I put all my weight on the wrench and got no where.
Wednesday: 20" impact extension on a 25" breaker bar WITH a 4' pipe extension. Nothing.
Then a 240ft-lb impact wrench. It just laughed at me.
Thursday: found an air compressor to borrow.
Friday: bought 625ft-lb air impact wrench. That b1tch came right the fawk off.
So, don't even bother trying without air tools. I stopped because I went to Clerks II Plus the weather went from mid 60's to mid 90's literally overnight am I'm freaking cooked- I'm going back to it tomorrow morning.
Old Aug 1, 2006 | 01:46 PM
  #72
Alchemist's Avatar
Ok final update: me likey. Install is only bad because of the bolt (and I did my timing belt at the same time to fix the belt tensioner so that sucked a little extra). My total was under $70. Pulley from eBay and I bought belts from my local parts shop (shipped from schucks.com). Thanks Coma!!!
Old Aug 11, 2006 | 01:52 PM
  #73
DriftRunSir's Avatar
awesome! good to hear about more swappable parts. congrats guys!
evo666: thanks for helping out...now, if you can convince the rest of the mirage guys to help out -=o].
Old Aug 12, 2006 | 09:18 PM
  #74
Evo666's Avatar
no problem, there's actually a few of us wondering through this site daily and making useful posts.
Old Nov 7, 2006 | 08:07 AM
  #75
gregivq's Avatar
http://*********.vstore.ca/product_i.../lancer-engine
A2 Designs sells the exact same pulley for $90.00 with the belts.
