Lancer-Mirage Compatibility Forum For parts that can be used on both Lancer & Mirage models, post/look in here.
mirage cam
Old Jul 23, 2006 | 05:26 PM
Mitsiman's Avatar
http://www.rpw.com.au/Products/Engin...pec4g93s16.htm
If everyone read this they will see exactly the difference between the stock 2.0 and stock 1.8 camshaft.
The 1.8 has 8 degrees more exhaust duration but slightly less lift than the 2.0 camshaft which woudl actually make it worse than the 2.0 camshaft for a turbo applicatin.
The 1.8 cam is not that much more aggressive than the 2.0 camshaft. Its more a case of the 2.0 motor is more restricted with teh intake manifold, longer stroke which makes it a lazier motor. The 1.8 engine with the shorter stroke, better manifold can rev harder and has tuning to suit that.
So I go back to it again - this camshaft is a nice mild improvement for the 2.0 cars for sure, but it is not going to gain a 10 - 15hp improvement and especially not more suitabel for forced induction.
But if the cams are goign cheap and you want somethign extremely mild then it will do a nice job, but if you are after some serious camshaft improvements, then when you compare teh specs to the rest of the RPW camshaft profiles, you will see the difference.
mitsbishi mirge
Apr 2, 2017 08:33 AM
Live4Redline
Lancer Engine Tech
19
Jan 9, 2017 09:55 PM
Mirage2.0
Oct 2, 2007 09:24 AM
bahamut
Lancer Engine Tech
May 31, 2005 12:06 AM
DN
Jul 7, 2004 01:27 AM
