Alarm removal.
Old Oct 8, 2010 | 07:30 AM
Antonovich's Avatar
Alarm removal.
So I have an alarm that was installed from the previous owner and some of the wires are cut and i'm looking to just take it out. Some of you have probably seen the engine pic, but i'm at work and will take a couple other pics later.
I can find the wires running from the fuse box and along the strut bar to the alarm which is attached to the left hand side of the engine. The only thing i'm unsure of is that the wires run into the engine firewall and i'm not sure how to check where they run or have any idea of what the would run to. any suggestions on removal?
Old Oct 8, 2010 | 06:03 PM
mrwilsonsaid's Avatar
the wires most likely run through the firewall to the ignition and separate from there. You basically need to take everything apart to get to the brain/wires
