Tire Rack Brembo rotors, look
Old Oct 28, 2004 | 10:18 PM
Pick_a_Fro's Avatar
yeh..it's the lug pattern
We got 4 X 100.
Old Oct 28, 2004 | 10:19 PM
twardnw's Avatar
pwn3d
doh, somebody slap me
Old Oct 28, 2004 | 10:32 PM
Pick_a_Fro's Avatar
<SLAP> idiot~!
Old Oct 29, 2004 | 05:14 AM
Archangelite's Avatar
why what happened?
Old Oct 29, 2004 | 06:37 AM
livelyjay's Avatar
Originally Posted by 03RallyLancer
they look nice do u know if they are coated?
They are Zinc coated, which is an anti rust coating. It will help protect the outer edge and center hub, but as soon as you start braking the coating will not longer be on the main section of the rotor. I'm getting these in the spring
Old Oct 29, 2004 | 06:46 AM
Kurt's Avatar
I have the Brembo slotted rotors. They work great with the Axxis pads that I got for them. They are worth the every cent that I paid for them.
Old Oct 29, 2004 | 07:32 AM
Powder's Avatar
ES owners could just buy them and have a machine shop redrill them for the 4X100 lug pattern. Shouldn't cost more than $20 or so.
Old Oct 29, 2004 | 07:34 AM
livelyjay's Avatar
For some reason I remember the OZ and LS rotors being different widths or something. I may be wrong, but I remember there being something slightly different besides the lug pattern.
Old Oct 29, 2004 | 08:35 AM
Kurt's Avatar
That's a good idea as long as the hub diameter is the same, the overall diameter of the rotor is the same, and the rotor thickness is the same. Also you take them to a good machine shop.
Old Oct 29, 2004 | 11:10 AM
.L.'s Avatar
.L.
they look nice do u know if they are coated? if not you might want to tape off the rotors and spray the center part with some high temp paint so it doesnt rust up. and .L. if you are getting them to shorten you stoping distance you are gonna be very disappointed... they might shortin it by a few feet... but there main purpose is to hold up better to high heat/stress situtations(like the track) where they stay cooler then none slotted rotors. In that respect they will help shorten your stopping distance.
thanks for the info. thats actually what i meant to say. i want something to perform better overall. not so much stop on a dime. but yeah...... thanks
Old Oct 29, 2004 | 11:42 AM
UPDATE***** heres the installed pics
Well here they are. im a man of my word and i dont post worthless threads saying i got new 'something' and show no pics.
Attached Thumbnails Tire Rack Brembo rotors, look-brembo1.jpg   Tire Rack Brembo rotors, look-brembo2.jpg   Tire Rack Brembo rotors, look-compare3.jpg   Tire Rack Brembo rotors, look-brembo4.jpg
Old Oct 29, 2004 | 11:44 AM
last ones
Attached Thumbnails Tire Rack Brembo rotors, look-brembo7.jpg   Tire Rack Brembo rotors, look-brembo6.jpg
Old Oct 29, 2004 | 11:47 AM
livelyjay's Avatar
Delicious
Old Oct 29, 2004 | 04:30 PM
only problem: should i have pressed the caliper cylinder back? then pump the brakes, cuz what i did was just slid the old rotor out and slid the new one in. when i started driving it around i made sure not to slam on the brakes at all as to not glaze them. so ive been taking it easy. already got 20 miles on them so its ok, but when i slow down it shakes a bit.
Old Oct 30, 2004 | 03:02 AM
ScLncerboy's Avatar
Those are figgin NICE!!!, i am hoping to do brake upgrades soon.
