New CF PRODUCTS
Old Mar 9, 2005 | 08:50 AM
  #46
pgmike's Avatar
id liek a radiator cover like from carbontrix but not with carbontrix price or crappy cf, i also would like a cf valve cover overlay if that is possible, not to replace it but to jsut voerlay it.
Old Mar 9, 2005 | 09:02 AM
  #47
OZLancerlunatic's Avatar
pgMike,
to do an overlay on the valve cover would be almost impossible because of the coils being raised....also, around the spark plugs you are gonna raise the height of the boot and change the tolerance of where it sits possibly causing a spark plug issue.
Mark
Old Mar 9, 2005 | 09:21 AM
  #48
akasirlancerlot's Avatar
i thkn carbon fiber from carbon trix is of a nice quality,... certainly be better than accolade///
Old Mar 9, 2005 | 09:26 AM
  #49
lol how do you get away with saying something like that and if i made that Id get a PM saying not to make rude comments.....
sometimes i wonder........
Old Mar 9, 2005 | 09:43 AM
  #50
pgmike's Avatar
lunatic, i wasnt saying to do a full one, im sure something can be figured out to make it work in some way or another
Old Mar 9, 2005 | 09:58 AM
  #51
what would you want covered then? wouldnt it look weird with only a part done?
Old Mar 9, 2005 | 10:06 AM
  #52
pgmike's Avatar
i dont know, id just liek to see soemthing, our valve cover is so boring and so is the rest of the motor bay, and i am def not painting it. also if accolade should make these things i would only buy them if they did not put their logos on them, i hate logos.
Old Mar 12, 2005 | 06:54 AM
  #53
omarboy25's Avatar
can you make the whole lancer body carbon fiber just for track day lol
i would like to see the valve cover i just painted mine red
sweet more cf parts cant wait
Old Mar 12, 2005 | 01:25 PM
  #54
wiretap's Avatar
http://www.aeronationusa.com/details.htm?id=846
There is a pic of a CF valve cover for the Scion xA/xB.
http://www.modacar.com/products/Acura/Integra/MODAVAC/
There is one for the Acura Integra. All you need to make a CF valve cover is high temp resin cured with heat and waterproof/oilproof design. If you do a search on google, they make the CF valve cover for many cars. Just don't torque down the valve cover too tight. It doesn't need to be that tight if i remember correctly anyways. Somewhere around 15ft/lb per bolt?
Old Mar 12, 2005 | 01:32 PM
  #55
spec sheet shows 30lb per bolt. the scion one looks like its a cover that goes over the original valve cover.....as for the integra one, never seen it used, the ricers prefer the red one and the jdm guys go for the yellow one
Old Mar 12, 2005 | 01:41 PM
  #56
wiretap's Avatar
Yea.. maybe it is 30lb. I heard the stock valve cover will bend to much and leak if you tighten it up too much. You are right about the cover for the Scion.. it just replaces the existing plastic toyota uses over their valve covers, my bad. As for the Integra, that is made of CF with aluminum inserts so when you tighten it up, it won't crack the CF. Heat resistant resin for that one as well.
Old Mar 12, 2005 | 02:12 PM
  #57
First off, that integra valve cover is $439, i see that is is heat resistant resin but what do you think the chances are that accolade will actually be able to build 1 correctly and fit perfect so it doesnt leak. This is totally different than a body kit that doesnt matter if it doesnt fit, if this doesnt fit you put your motor on the line, not just looks.
Also,the chances they they can produce it cheap.......not possible. Their body kits are worth less than $440 so I don't think many members would pay that for it.
Then again, there are people here that dont care about things not fitting so be it I guess, take your chances.
Old Mar 12, 2005 | 06:10 PM
  #58
blacklancerr's Avatar
i want some kind of engine cover...for example:
or:
i think it would clean up our engine bay SOOO much!
CF or plastic...either way.
Old Mar 12, 2005 | 07:34 PM
  #59
ACCOLADE's Avatar
Thanks for all your guys Comments.
I know that so many people have try to put us down by other companies, So this has made us more motivated to be competitive, More companies try post unwanted and rude comments, more we will pursue on develop products with QUALITY and THE BEST PRICE,
Remember we started very small with the lancer community. we may had done errors, but always improved and improving more and comments which are unwanted makes us work really really hard to make sure we put out the best quality+ best price.
You will be amazed with our prices. Infact we will first give 2 cars free CF parts so they will test fit for us and WRITE comments,
Our First Priority will be QUALITY - I and David will make sure that all products will the best price so that all you forums members can afford it !!!
Again we are here to serve the lancer community. not to make a personal battle with other vendors over here.
Old Mar 12, 2005 | 07:37 PM
  #60
irulea2's Avatar
I'll put my car up for the test parts.
