Best tire size?
Old May 6, 2005 | 06:37 PM
mitsuozboi's Avatar
Question Best tire size?
Say you have a 17 inch wheel on a 03 lancer. What size wheel do you want so that it fits in the wheel well nice but isnt a rubber band.
Old May 6, 2005 | 06:53 PM
TeAmEmPeRoR's Avatar
https://www.evolutionm.net/forums/sh...ad.php?t=50809
should have all the info yer looking for.....hopefully...haha
there's a tire calculator there you can use.
Old May 6, 2005 | 06:54 PM
mitsuozboi's Avatar
thx, im gonna check that out
Old May 6, 2005 | 06:58 PM
oh yah, next time you got tire ?'s, put them in the tech forums under tires,wheel & suspension. just givin ya a heads up before others flame you and tell you to search next time...lol
Old May 6, 2005 | 07:01 PM
mitsuozboi's Avatar
so say I go with some 17x7 enkies, what would be better, 205/40 or 215/40?? Ive seen a lotts lancers on EvoM with both size tires.
Old May 6, 2005 | 07:02 PM
mitsuozboi's Avatar
oops, ill do that...next time i got a question, thanks.
Old May 6, 2005 | 07:10 PM
wiretap's Avatar
205/40/r17
Old May 6, 2005 | 08:24 PM
Dreamartist's Avatar
^ oh yeah!
Old May 6, 2005 | 10:50 PM
^really?.... I figure that would be alright for an ES but not the OZ.
I dunno, I'm just going by the tire calculator, and I think the closet for the OZ if yer running 17's is ummm....let's see.....205/45/17.
Old May 7, 2005 | 09:13 AM
OZLancerlunatic's Avatar
315/40-17
Old May 7, 2005 | 09:18 AM
N1te's Avatar
Originally Posted by OZLancerlunitic
315/40-17
rofl
Old May 7, 2005 | 04:22 PM
Melaz425's Avatar
205-45-17. 215-45-17 would be nice but ive heard they rub.
Old May 7, 2005 | 06:32 PM
TeamAccolade's Avatar
215/45R17 is what i run. i get rubbing at a full wheel turn. ( meaning wheel cranked all the way. ) otherwise none at all.
Old May 7, 2005 | 09:54 PM
FlLancer's Avatar
^ same here but with progress springs as well.
Old May 7, 2005 | 10:02 PM
vikktorlv's Avatar
205-40-17 or 215-40-17
Well,
the factory wheel is 185-60-15
to keep the wheel size the same. meaning outside Diameter. Which is what your speedometer, and odometer are looking at for accurate calculations you use the +1 +2 calculation.
so adding 2 inches to your Rim, gives you a 17" rim . so add your 2" inches and move up the tire size that keep your "OVERALL" wheel diamter as close to factory as possible. Otherwise expect your speedo to be off and get pulled over possibly.
