gauging interest in projector retro in stock head lights
Old Sep 28, 2005 | 06:14 PM
  #31
Tweak3D's Avatar
I did have ABS around the shroud at first, it melted.....
Aluminum tape worked for a while but produced some glare from inside the projector, need to use something not as reflective.
Old Sep 29, 2005 | 08:32 PM
  #32
Tweak3D's Avatar
bump, I really want to see if you can get something going. I will help you as much as I can, maybe we can come up witha good design if we puyt our heads together.
Attached Thumbnails gauging interest in projector retro in stock head lights-1.jpg
Old Sep 29, 2005 | 08:42 PM
  #33
Z_Lancer_Man's Avatar
well, I just bought a HID kit using H1 bulbs with thehopes of installing the kit in some new housings a.k.a cedias. Unfortunately sounds like you guys are using the stock headlights. Anyway to retrofit an H1 bulb holder for the stockers if I can't find some cedias?
Old Sep 29, 2005 | 09:29 PM
  #34
Tweak3D's Avatar
when you do a retro you don't use the stock bulb holders. generally you want to use DS1 bulbs which are what OEM bulbs and projecotrs are/use. You can get projectors that use H1 but they will not be OEM projectors, thus you will not have an OEM style cut off line.
Old Sep 29, 2005 | 10:18 PM
  #35
lookslikeanevo's Avatar
prejectors that i use will prolly be h1, but well see
Old Oct 1, 2005 | 10:53 AM
  #36
Pick_a_Fro's Avatar
I wished I lived in Washington or in Socal to help either one of you. I'd really like to try this out and patent it, hehe. Maybe I can try this out on my own, but I don't really like the idea of hacking into my CEDIAS, ouch. Another reason is it's gonna suck not having headlights on my car for that time period.
Old Oct 1, 2005 | 11:36 AM
  #37
akasirlancerlot's Avatar
again rigo i have an extra set of lights. err kevin does.
Old Oct 1, 2005 | 11:59 AM
  #38
Tweak3D's Avatar
I would say buy an extra pair to work with just in case. If you have any questions I know I will be willing to help you as much as possible. I am sure lookslikeanevo will do the same. One reccomendation i can give you know is learn to work with JB weld, I used gobs of this stuff and if you do screw up, all you have to do is fill in the hole or join the crack, let it cure, sand it down a bit, and then paint and tada its fixed.
-Justin
Old Oct 1, 2005 | 05:47 PM
  #39
blacklancerr's Avatar
[hijack]
i have some stock lights for sale for cheap if you want them
[/hijack]
Old Oct 1, 2005 | 09:51 PM
  #40
-Justin
yep
Old Oct 2, 2005 | 06:07 PM
  #41
david02's Avatar
I would consider a set if you could keep the price around $500-$600. That's good deal considering the cost involved of headlights, hid kits, and any other materials included. The headlights from cerious performance were said to be around $1300 shipped to your door and they are not hid. Would this be plug and play or hard wire? Also I would want mine in stock housings, not crazy about the Cedia black housings.
Old Oct 2, 2005 | 10:19 PM
  #42
what do you mean sotck housings? chrome?, i may or may not go that route for a few reason, but 'well see...it will be hard wired, unless i find a 9007 projector
Old Oct 26, 2005 | 03:11 AM
  #43
Pick_a_Fro's Avatar
is this still being done?
My left headlight is getting condensation bad and I need to fix it somehow. Anyways, the projector idea I really want to do because I want to put HIDs in my car w/o the glare. Hopefully Rigo you can do it or I might have to see how much HIDretro.com charges.
If they can make it like this, this would be bad ***!
Attached Thumbnails gauging interest in projector retro in stock head lights-13.jpg
Old Oct 26, 2005 | 05:50 AM
  #44
peelslancer's Avatar
anybody got just a stock headlight??or cedia??
Old Oct 26, 2005 | 05:54 AM
  #45
I have blacked out stock headlights for sale... PM me.
On Topic - what projectors would you be using for the retro?
