???? for people w/ EVO VII spoiler
Old Apr 17, 2003 | 06:04 PM
t-dotlancer's Avatar
I just received my spoiler today and there are NO holes pre-drill behind the doors on the sides, and NO holes for the cross section either. Did anyones come predrilled???
Old Apr 17, 2003 | 06:27 PM
nastea's Avatar
where did you get it, i've bought both a fiberglass Evo 7 and carbon fiber evo 7 spoiler, and they both had all the holes, screws/bolts and gaskets
Old Apr 17, 2003 | 07:58 PM
i am going to drill my own holes.....any ideas on what kind of sceews to use, or what i should use for a gasket.
Old Apr 17, 2003 | 08:53 PM
any ideas on what to use for gaskets? and screws?
Old Apr 17, 2003 | 09:36 PM
nastea's Avatar
now your talking about holes in the wing/spoiler right ?
Old Apr 17, 2003 | 09:44 PM
on the two side peices and on the middle wing, also you knoewanything about gaskets. the only holes i have pre-drilled are the ones on the bottom for the trunk. any help with where the screws and gaskets go, and how may screws would make life alot easier.
Old Apr 17, 2003 | 10:49 PM
pisetup's Avatar
Return it and get one with pre-drilled holes. If you are NOT an expert in fiberglass, I wouldnt recommend you drill holes in them.
Old Apr 17, 2003 | 10:58 PM
DRC Imports's Avatar
just go to a good body shop and tell them you just need the wing put on. wont cost that much and itll get done right !! if you do it yourself use woodscrews for the fiberglass and flat round washers just a bit larger in diameter?? spelling?? than the head on the screw.
just my .02
Old Apr 17, 2003 | 10:59 PM
i dont know what to do for gaskets !!
